News Microsoft unveils haptic feedback monitor
Discussion in 'Article Discussion' started by Gareth Halfacree, 3 Jul 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    I don't understand. I've never used a touchscreen where you physically need to push it back.
  3. Gareth Halfacree
    4 Dec 2007
    That's the point: Microsoft has created something new. If it helps, imagine it as a monitor mounted on a Novint Falcon.
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    If this means one day my phone will fight back, I want my 3210 back!
  5. stuartwood89
    20 Aug 2008
    It means that typing on touch screen phones just may get tolerable.
  6. Guinevere
    Guinevere Mega Mom
    8 May 2010
    No. It's got nothing to do with touch screens phones unless you mount them on a robot arm.
    This is just another research project by MS. Don't expect it to result in anything close to a real product.
  7. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    When the article mentions 3D monitor is that a true 3D display or a stereoscopic displays ?
  8. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    I still have mine but not used it in years, wonder if there's win7 drivers for it...
    I remember some of the tech demos that came with it (one was as if you were moving the stick through molasses another was as if your were trying to balance the stick on the tip of a pyramid. Shame the only real application seemed to be the flight sim.
  9. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    Well I already have a potential use for it. Flightsim... You're using A10 sim and looking at the instrument panel using your Track IR... you can lean forward and when you touch a virtual button in the cockpit... you feel it.
    Having said that... I think a monitor on a robot arm maybe is a bit limited.
    My ideal would be Oculus rift and a haptic glove with Leapmotion for accurate hand positioning.
  10. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    Its called Swipe, and its already very tolerable. If your on a Crapple and you don't live typing, maybe you should consider switching.
    Also I agree with Guinevere, this is highly irrelevant to cellular screens in the near future. Ultimately the tech sounds like it could be really awesome though. I think these concepts go well beyond gaming too. Immersive interaction (while absolutely not needed) could really change professions like drafting. Generate a 3D model, set the material, and be able to touch the screen and interact with it as a solid is a pretty awesome concept.
  11. Gareth Halfacree
    4 Dec 2007
    Active-shutter stereoscopic - you can just about see the glasses in the picture.
    Same - although my PC doesn't actually have a gameport anymore, so it's a bit redundant other than as a relic of a bygone era.
    Gamers used to what passes for 'force feedback' these days don't know what they missed. Forget a bit of a rumble effect from a vibration motor or two; the Sidewinder Force Feedback could do so much more. Best memory: I was playing the excellent Independence War, which put you in command of a massive battle cruiser flying through space. I got into combat, and a lucky shot snuck past my shields and took out my lateral thrusters. What did the joystick do? Lose auto-center capability on the horizontal axis; if I moved the joystick vertically it would resist me as normal, fighting to return to the centre point, but it just flopped limply in the horizontal axis. When my engineers had repaired the damage, the joystick shuddered back to life and worked as normal.
    Absolutely incredible stuff, and doubly so when you realise that beyond the Novint Falcon we basically have nothing like it available today.
  12. Blademrk
    21 Nov 2003
    Mine came with a game port to USB adapter, so I've always used it through USB.
  13. Gareth Halfacree
    4 Dec 2007
    Sounds like you have the Force Feedback 2, then - mine's the original Pro model, which isn't USB compatible. Well, without a proper USB connected gameport adapter, which wasn't bundled.
  14. longweight
    7 May 2011
    I think it was the Blackberry Bold that had a clicky touchscreen, it felt horrible to type on!
    I loved the haptic feedback on my HTC Desire but I really don't miss it on my Nokia 920.
    Cool idea though!
  15. Blademrk
    21 Nov 2003
    Just checked (as I've got home) yep, I've got the Force Feedback 2 (and it is native USB, not through an adapter) I also have (an extremely dusty) Microsoft Precision Pro (which uses a similar frame to yours, but without the force feedback) which has a gameport socket and a USB adapter.
    Edit: Well the precision Pro works, just need to find a power cable to test the FF2 one :)
    I need to dig out my Star lancer discs...
