News Microsoft withdraws, re-releases 10 Patch Tuesday updates
Discussion in 'Article Discussion' started by Gareth Halfacree, 16 Sep 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Is this just a side-effect on Microsoft's insistence on releasing patches on a particular day of the month? Is it just that patches written later in the monthly cycle have less time to be tested properly before release, and so are more likely to contain bugs?
    Inquiring minds need to know!
  3. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    All those NSA/GCHQ backdoors causing problems perhaps ?
  4. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Hmm... Not sure they have done it properly though. I was getting the three updates that continuously tried to install until sometime Saturday I think when after another check of WU the three updates disappeared and WU reported that there were no update to install. So I agree that they were withdrawn but after checking WU once again today after reading this article my WU has not found any further updates to download and install. So at least at my end I have not had the 'fix' yet. Are they 're-issued' to WU but haven't been released to the public yet?
  5. Gareth Halfacree
    4 Dec 2007
    They should be live on Windows Update now; if you're not being offered them, it's possible that they did actually install successfully at some point - one of the bugs was to fail the install constantly, the other was to actually install but act like it had failed the install constantly. Check your list of installed updates, see if they appear in there - if so, you're golden. Theoretically.
  6. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Blame all those to the NSA/GCHQ backdoors !
  7. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I think the QA department needs sacking.
  8. SchizoFrog
    5 May 2009
    Thanks Gareth... Do you happen to know if the reissued updates have the same KB numbers?
  9. SchizoFrog
    5 May 2009
    After checking I can confirm that the three updates in question were all installed. :)
  10. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I like patches, but that's probably because I was born in the 60's
