Mid tower / small mATX case for dual 240 rads?
Discussion in 'Watercooling' started by abezors, 28 Feb 2018.
  1. abezors
    abezors Lurking since '08
    21 Apr 2010
    Hiya, I'm currently using a Fractal Node 804 for dual 240mm rads. It's an mATX/ITX case with two separate compartments like the Carbide 540. The case is quite flexible with rad placement but I'm fed up of using a cube case (takes up too much footprint on or under my desk) and want to go back to a regular mid tower.
    Any examples of mATX cases with support for twin rads?
    I prefer the minimal style of Lian Li, Jonsbo, etc. Not an open meshy or gaming case with plastic chunks all over it...
    Cheers for any ideas :)
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    Fractal Design Define Mini C or Phanteks Enthoo Evolv Micro-ATX are both matx specific cases that you can get both rads in.
  3. abezors
    21 Apr 2010
    Had not come across the Phanteks, so thanks!
  4. The_Crapman
    5 Dec 2011
    Really nice cases. My friend has the full atx Evolv and said it was good to build in. They do them in black, white and gun metal grey, windowed and glass panel ones too.
  5. TheMadDutchDude
    23 Aug 2013
    Beautiful cases, but be careful... the airflow is severely hampered when you fill both the front and top with rads.
  6. The_Crapman
    5 Dec 2011
    Easily solved with deltas :naughty:
    TheMadDutchDude likes this.
  7. abezors
    21 Apr 2010
    That's a very good point Dutch, I saw someone mention that elsewhere... I'm probably asking for too many compromises looking at small and discreet mid towers so might look at slightly larger cases. Currently very tempted by the Jonsbo RM4 or UMX4... pricey though.
  8. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    Mastercase Pro 3 is doable with a 240 and a 280
