A/V MIDI Composition Software
Discussion in 'Hardware' started by acron^, 1 Nov 2005.
  1. acron^
    acron^ ePeen++;
    15 Oct 2001
    I thought this'd be better off in AV rather than Software because I'm likely to get a more knowledgable response.
    I simply wondered if anyone knew of any free/cheap MIDI Composers? Not one with a keyboard input read, just with a score sheet that I can add to.
    I've Google'd but found nothing great.
  2. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    If you like oldschool there are plenty of free trackers about, skale, buzz etc are all fairly decent
    As far as actual sequencers go FLStudio can be had for ~30 squids in its express version, though its prolly worth shelling out for the normal / producer edition depending what you want to do. Producer supports asio and various other bits and pieces
  3. jgrade
    jgrade What's a Dremel?
    2 Mar 2004
    I may be able to help, but what OS are you using? (Mac or PC)
  4. acron^
    acron^ ePeen++;
    15 Oct 2001
  5. lcdguy
    lcdguy Minimodder
    25 May 2004
    midi software i have used and is realatively cheap in comparison are:
    Voyetra Midi Orchestrator Plus
    and
    Coda Soft's Finale or Finale Notepad.
