Modding Midi tower case or bigger with front 120mm fan
Discussion in 'Modding' started by JonDixon, 26 Oct 2003.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Okay,
    Im looking to get rid of my watercooling setup as my daughter finds it interesting to pull on the hose.
    So its time to buy a new case and look into quiet air-cooling again.
    I have an 2800XP and a couple of Maxtor 120GB SATA drives plus the usual cd-rom and DVD-R
    plus if poss I'd also like to keep my 80GB IDE hdd as well but this is optional.
    So I need to find a case to hold all this gear and allow me to use the minimum number of fans on 7v or lower to keep it all cool without sounding like a 747.
    Im already looking at the Aero7 cooler but can someone recommend a case? I run everything at stock and have a couple of quiet evercool 120mm fans Id like to reuse.
    Budget is max £100 incl p&p
  2. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    I can recommend the Aero7+. I use that. I mounted the speed adjusting at the back. So when i play games i just crank it up a little. But when only idle i slow it right down....It's real quiet.
    It cools my xp3000+ down to 32 while playing games.
    The case is really down to your own taste. A simple *cough* beige one or a all singing all dancing alu one.
    And do you plan on modding it??? :D
  3. LCDNinja
    LCDNinja What's a Dremel?
    22 Oct 2003
    I would have recommended the Lian Li PC-6070, but with your budget, that's right out.
    Try going with an Antec Sonata case. Nothing but high quality there
  4. JonDixon
    12 Mar 2002
    Some simple mods maybe.
    Dunno if I want to go down the window/lighted route again.
    Have just found this case which meets spec of 120mm fans
    http://www.tekheads.co.uk/web/product?product=602020&
    Looks like it might do. Read some reviews which rated it.
    Anybody got any other ideas?
  5. GNU rider
    GNU rider What's a Dremel?
    22 Oct 2003
    thats a sweet case! quite a bit of modding potential there......
    btw, looking at the price it says something about including and excluding VAT, what is that? is that something UK specific or another term for a PSU?
  6. JonDixon
    12 Mar 2002
    VAT is (value added tax)
    Have seen some more reviews on the case and they all date back to Jan 2002.
    Might be a bit old hat now. So maybe I need to keep looking, but its definately at the top of my maybe list.
    I have to consider the modding potential if I bought it, to bring it up to date.
  7. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    Hey Jon that case is neat!
    2x120mm, Alu, Wide etc.
    It has a removable (stainless steel) MOBo tray - the Sonata does'nt....
    It has great potential but a bit Old lookin.
    Mat :)
  8. olv
    olv he's so bright
    23 Sep 2002
    wouldn't a simpler solution be to put the side panel on your case or to have a completely internal setup where little exploring hands cant grab?
  9. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Look for Compucase's LX-6A19. It's basically a clone of Antec's SLK3700, but cheaper since it doesn't come with an Antec PSU (although if you don't have a good PSU, then you should go for the Antec). 120mm fans front and rear, 4 5.25" bays using rails, 2 external 3.5" bays, and 5 internal 3.5" bays with grommets in the screw holes for noise surpression. As you can probably tell, I own this case, and I'm just about to start modding it.
  10. JonDixon
    12 Mar 2002
    Im just not confident on having the reservoir inside case. I have also in the past Ive had a pump leak. I think my wife would be a lot happier without the water
    I'll have a look at the Compucase's LX-6A19 case. Although Ive ordered the YCC one.
    Will have to see what I can do to the front, becuase I want it to look a bit smarter.
