Cooling might try modding, need some help with water cooling
Discussion in 'Hardware' started by DarkLord7854, 23 Jun 2005.
  1. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Yea I'm new, and was looking for modding forums to get some help as I've never done this. First thing I did was make the plans:
    Plan part 1
    Plans part 2
    I think the water cooling set-up is correct, not sure, but I have the worst budget ever, probably won't get over 200$, probably less. So if you could point me to the least expensive ways to make a reliable water cooling set-up for just the CPU, and any fans really need to be quiet, my current case is so damn loud, you can hear it from upstairs.
    Well thanxs ahead for help given :D
    P.S. I might not mod it, depends on the funds available compared to prices :sigh:
  2. alpha112
    alpha112 Minimodder
    23 Aug 2004
    For $200 you could easily make a good setup. Ive been buying 2nd hand and so far I have a Eheim 1046, P4 TDX, Maze4 GPU and 2m of Tygon for £57 (~$100) all I need is a res and rad and Im sorted, I think.
    Second hand is definitely going to be cheaper than new.
  3. DarkLord7854
    22 Jun 2005
    Sounds like a winner, where can I get second-hand products.
  4. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Ebay have some, but not a lot of good stuff.
    When you have 75 posts you can get to the Sale/Trade forums here and buy whatever is offered there, its where I got most of my bits from.
  5. DarkLord7854
    22 Jun 2005
    Ok cool... now to do some spamming :worried: :naughty:
    EDIT: Watch it... :grr: :D --nexxo
  6. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    That pump is not the best choice for the other components you've sourced. It is a great pump but is more suited to low flow.
  7. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    I know the feeling... I've still got like 50 more posts to go before I can see the for sale forum. And by that time I'll have bought most everything I need.
  8. ralph.pickering
    6 Apr 2005
    And for cheap rads, you could try a car breakers yard. I got a heater matrix from a 2003 model Corsa for £5.
  9. DarkLord7854
    22 Jun 2005
    I don't have a car breakers yard anywhere near my house, would take about a 3 hour drive before I find one.
    So I'll just have to spa- post my way through... :D
  10. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    If your located in Miami you'll find a load of junk yards on your doorstep....... Google
  11. biff
    biff What's a Dremel?
    8 Jan 2004
    Even if you have to buy a new heater core it will be about half the price of a special built rad, in my area anyway. I got two '86 chevette heater cores for not much more than a BIX, and the HCs are quite a bit larger. Also an '86 chev. HC has approximately (very loose calcs. done here) the same surface area as a BIX2. I doubt the performace is the same as a BIX2 since you can only get one 120mm fan on the HC instead of two... but still. It just wont be as pretty and you may (probably will) have to mod it a bit... but that's the fun part.
    Just my 2 cents.
  12. DarkLord7854
    22 Jun 2005
    Allright, so I'll have to drag my parents into getting me to a junkyard, get a car rad from the yard, mod it, install on the comp, buy a pump, create my egg-shaped reservoirs, get the tubing, make my waterblock and I'm done.... phew
  13. biff
    8 Jan 2004
    DONE? It's only just begining. :naughty:
  14. DarkLord7854
    22 Jun 2005
    well for the water cooling part yea, then comes the real killer (for my parents that is) of funding my modding :p
