Linux Minecraft; Official Bit-tech server
Discussion in 'Gaming' started by Stickeh, 6 Oct 2010.
  1. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Sorry for not being on all that much ATM guys, busy and stuff :<
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I did this the other day - launch the server with "hellworld=true" set in the server.properties file, then explore a bit till you get Hell chunks generated.
    You can then restart the server in Hellworld=false mode, and the generated chunks will still be there. New chunks after that point will be generated as normal world.
  3. Stewb
    Stewb What's a Dremel?
    16 Dec 2009
    I'm guessing the only problem with this is that while its in hellworld=true you get ghasts spawning everywhere in your map?
  4. badders
    4 Dec 2007
    No, actually - I'm guessing they're not implemented correctly for SMP, as I haven't seen one yet. In fact, while I had hellworld set to true, I don't think I saw any mobs at all.
  5. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Ghasts are ****ing evil, I suppose that hell was meant to be hard though!
  6. TCoZ
    TCoZ Buffalo buffalo buffalo buffalo...
    3 May 2010
    Are we fighting the same ghasts? They're just a bit of a nuisance in my opinion. They're so inaccurate and you can punch their fireballs back, and you don't take much damage from being in the blast radius of the fireball. Food is abundant in hell, too, so you can just heal back any damage you take.
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Aaaah, server down! So typical, i was about to finish my work >.<
  8. theskirrid
    theskirrid What's a Dremel?
    15 Dec 2009
    Also a ghast will snuff it in 2 arrows, providing you hit it in the dangly bits.
  9. morris8809
    morris8809 Minimodder
    30 Dec 2006
    just a reminder the server im hosting is always up so if the other is down you can join mine to mess around on if you want. Just pm me and ill give you the ip. One or two are on it with no probs yet so we will see.
  10. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    I finally have time to get on, and I find the server down?
    I'm on it...
  11. Guest-2867
    Guest-2867 Guest
  12. Journeyer
    31 Aug 2006
    Well, the server had locked up, so no save I'm afraid. Unsure whether or not Stickeh's auto-save feature has done it's job. Cross fingers chaps.
  13. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
    Lost the same work twice in one afternoon >.<
  14. Journeyer
    31 Aug 2006
    FU**!
    Can't save this time either it seems.
  15. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    FFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
  16. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    If this means we're still running on late last night's map i can already start that up for you guys on my server.
  17. Journeyer
    31 Aug 2006
    No, it has been saved since then.
    Edit: Will not have lost more than I did this time, but others may.
  18. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
  19. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    And down again.
  20. Xtreme_Machine
    Xtreme_Machine Survivalist
    6 Jul 2008
    Hey Stickeh. I've been playing around with hey0 mod myself...
    You should rely install the Daylight plugin
    Can be en/disabled via /enableplugin Daylight or /disableplugin Daylight if you want normal day/night cycle. Verry usefull when players want to build a lot. Like i said, when they are done building, just disable the plugin en taadaa.. normal cycle. :D
    Now the admins/mods dont have to type /time day anymore ;)
    Edit:
    Oh and maybe the Bedrock Gap insurance too. Keeps players from falling through the map :)
