Build Advice Minecraft PC
Discussion in 'Hardware' started by Cookie Monster, 5 Jan 2013.
  1. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    will the rc car still work afterwards, if so you could create a trailer for it and have a normal power supply with wires going into the back of the car. Just an idea.
    Also what about wiring 2 pico power supplies together like this.
  2. atc95
    3 Dec 2012
    In terms of a card I would suggest this, it is the one of the best you can get for £50 and has the ribbon cable you mentioned^.
  3. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    No the car won't work after, and the trailer won't fit in with the theme I'm going with.
    I've looked at that graphics card, I'm thinking I could cut out a hole in the chassis as I'm going to try mount the card upside down, that way the hole would fit around the heatsink, creating a bit more room and allowing it to breath.
  4. craigp84
    craigp84 What's a Dremel?
    28 Oct 2009
    Can't offer any advice but just wanted to say I wish my old man had built a PC inside a car shell when I was wee!
    Seriously cool sounding mod. Needs some pics when it's done!
  5. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I agree! Work LOG, work LOG, work LOG (everybody join in....)
    Cookie what is the maximum height you have to work with after fitting the cpu cooler?
  6. loftie
    loftie Modder
    14 Feb 2009
    As someone pointed out, Minecraft is a strange beast. Just remember to install Optifine
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Would have been perfect for an AMD APU build. Even an E350 would be enough.
    Sent from Bittech Android app
