News Mini ASUS RTX 2060s are on the way soon
Discussion in 'Article Discussion' started by bit-tech, 19 Feb 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Over maximum slot height, double-slot cooler, and the card is longer than an FE card.
    Well done Asus, good job, you've made your 'mini' card larger than stock! AND dropped a DP output for absolutely no good reason!
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
  4. edzieba
    14 Jan 2009
    Ah, I'd been converting to mm and fudged something somewhere for the length. The rest of the dimensions re still pretty poor though, and as you say there are shorter cards available already.
  5. frack
    frack What's a Dremel?
    28 Feb 2020
    bud the question is... do we really need of so many small GPU cards?... people usually think as biggest as possible...
  6. edzieba
    14 Jan 2009
    We need small cards, but these aren't that.
    Small cards would be bus-powered half-height-half-length cards, or single-slot cards (either stock WC without needing to physically cut off a DVI port from the back panel, or single-slot air like the Galax Katana cards), or half-length cards that do not go overheght or occupy "two-and-a-half" slots etc.
  7. Vault-Tec
    30 Aug 2015
    Is this even any smaller than the 2060 KO?
  8. adidan
    25 Mar 2009
    Inches - really?
    Diletta Graziosi and yuusou like this.
  9. yuusou
    yuusou Multimodder
    5 Nov 2006
    We're taking our country back and with it our own measuring units!
    adidan and GeorgeK like this.
  10. GeorgeK
    18 Sep 2010
    #GetImperialDone
    David likes this.
  11. adidan
    25 Mar 2009
    Ha yeah, our own Roman based units. :lol:
  12. adidan
    25 Mar 2009
    That'd be perfect then, everybody's happy :)
  13. frack
    28 Feb 2020
    how old do you think it will still take? ahaha
  14. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    small is not how i'll call it lol
    they could be very useful for small form factor cases and itx build, but that one is not so small lol
    why can't everyone use cm is much easier
  15. edzieba
    14 Jan 2009
    mm or bust! cm are a bizarre cludge that breaks the 10^3 separation standard for all other units. Nobody uses hectolitres or centivolts!
    Arboreal likes this.
  16. frack
    28 Feb 2020
  17. Diletta Graziosi
    27 Feb 2020
    Always better than inches!
Tags: Add Tags
