Case Mod - In Progress Mini Box - Cooler Master Elite 120 Advanced - 01/02/ 2013 - Carbon Fiber!
Discussion in 'Project Logs' started by Marcos_Viegas, 31 Dec 2012.
  1. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Welcome to my new project using the mini itx case Cooler Master Elite 120 Advanced, the first changes were to "clean" the inside of the case:
    Here's the video (in portuguese... :lol:):
    The cable management is messy, but I made this "montage" only to get a sense of how the VGA and PSU would stay in the case.
    I started to modify the sides of the case, first place opening for installing the radiator 240:
    Now taking all the side which will be installed in a different way, I will show in the next ups:
    And now where the cut will be the VGA:
    And here a test with the radiator:
    In future posts I will detail all the hardware used in the project.
    I hope you enjoyed.
    Now news and finishing of parts, only next year.
    Happy new year everyone!
  2. Marcos_Viegas
    6 May 2010
    Well, now the news ... The Water Cooler "custom" created by "Cooler Marcos" (in portuguese):
    And here pictures of how the new WC was installed:
    Next step will be to cover for VGA and also for the fans that will cool down the WC.
    Thanks to all!
    patara likes this.
  3. patara
    patara life is wonderful
    7 Apr 2012
    :thumb:the video card beautifully looks, (devil's translator of languages)
  4. Marcos_Viegas
    6 May 2010
    Thanks dude :thumb: :D
    I got the feet that I will install in the case, are known as "spykes" of ViaBlue, following the manufacturer's link: ViaBlue Spikes
    And here the pictures:
    Here they installed:
    I hope you enjoyed.
  5. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    oo man I have always wanted to use spikes for a build glad to see someone else doing it! they look brilliant!
  6. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    DAYM those spikes!
    good to see what can be done with a small build!
  7. Marcos_Viegas
    6 May 2010
    These "spikes" are very stylish, a friend of mine traveled to Germany and bought me this kit, I was lucky to get away with what he brought up.
    They lend an air of "style" to the project, since the first time I've seen in a sound box, I wanted to buy some to test on a project, but as I needed a case "small" have not had the opportunity to test before, but I liked the result. :D
    They are very stylish even, really liked was how the visuals, combined with a very small case. :thumb: :D
  8. Marcos_Viegas
    6 May 2010
    And for those who want news ... are below the photos.
    I did the cover for VGA acrylic "fumê":
    But it was not good, it gave some problems when folding and ended up crooked and there was to trash... Furthermore, in case the ASUS DirectCUII was only 3mm off the case, so I decided to do instead of cover, a frame.
    And here are the phases, first glue the sheets, 2 and 1 aluminum acrylic "fumê":
    I used Scotch epoxy glue Quick-Dry.
    The next step was sanding 3 corners in 45º:
    He took a heavy work and made a mess clueless, but the end result until it was good.
    Still lack the finish and make the cuts to the frame.
    I hope you enjoyed.
  9. _-..zKiLLA..-_
    _-..zKiLLA..-_ What's a Dremel?
    8 Jan 2008
    Cant see the pics mate
  10. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    interesting build!!! but 12-channel fan-controller for mitx case is a bit overkill IMHO :)
    and that spikes is good find!
  11. Cheapskate
    13 May 2007
    It looks like you got a little too rough with the sanding.:eeek:
  12. Marcos_Viegas
    6 May 2010
    Try again, maybe slow to load. :thumb:
    I got this controller from my other project that I wore all channels. :naughty:
    I also really liked the look of the spikes, they left more stylish to the case. :D
    I'll still give the finishing with sandpaper grain smoother, the piece is "unfinished" :dremel:
  13. Marcos_Viegas
    6 May 2010
    And who was anxious for news, first I have to say that I gave up the idea of ​​making a cover for the VGA, because after installing I did not like the look, it was at odds with the look, so I chose to leave out, and all enveloped with adhesive 3M carbon fiber 3M™ Scotchprint® Wrap Film
    Bonus:
    I hope you enjoyed. :thumb:
  14. PcJunkie209
    PcJunkie209 What's a Dremel?
    3 Sep 2011
    Awesome work! I'm digging the open gpu and feet!! :)
  15. Marcos_Viegas
    6 May 2010
    Thanks man!
    Glad you enjoyed it, I tried to balance the visual, to be "clean", "stylish" and somewhat "traditional" with the colors. :thumb:
