Mini clothing dryer indoors?
Discussion in 'General' started by keir, 24 Aug 2008.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    Bit of a weird one guys, we have this little cloths dryer and it's not hooked up to an exhaust so when we use it, I have to pick it up and put it in the garden. (for the heat)
    Now do you think it'd be ok to place in the downstairs cloak room (only when in use of course) as it's got an extractor fan in there.
    I can't see anything on the dryer that says how how it gets but tbh it's a bit **** so it's not that hot.
    I'm not really sure what damage it can do, but I suppose I don't want to open the door to check on the washing to find theres condensation all over the walls.
    cheers.
  2. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Ooh, I don't know dude - I'd recommend against it. The exhaust puts out all sorts of lint and humid air and the area might get mildewed pretty fast. Lint itself is highly flammable and contact with a naked flame will turn your cloak room into an oven pretty fast...
    I'd put it against an outside wall and do it the usual way
    Hope it helps :thumb:
    MGT
  3. FuzzyOne
    FuzzyOne
    19 Sep 2002
    You can buy a little plastic box that the filter pipe goes into, I can't for the life of me remember were I've seen them tho, they have been around for years and designed just for this job.
    Do you ever get a betterware catalogue?, I have a feeling I've seen them in there
  4. modgodtanvir
    28 May 2007
  5. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    You could get a condensing dryer if money allows.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    No, the one I've seen advertised is more of a water-filled box to condense the steam and trap the lint. FuzzyOne scores 10pt with Betterware.
    But Amazon review not so hot.
  7. RTT
    RTT #parp
    12 Mar 2001
    Vent the dryer exhaust into an air con unit!
  8. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    Duct the dryer directly onto the extractor fan unit, just don't turn on the fan and the dryer will blow the stuff out?
  9. <A88>
    <A88> Trust the Computer
    10 Jan 2004
  10. keir
    5 Oct 2003
    Hi guys, I doesn't have a exhaust pipe/tube/duct/thing.
    The heat escapes from the front.
    This is the only thing I could find, but it may give you an idea of what I'm dealing with - link
    edit - oh and it's a creda compact reversair sensadry system
  11. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    omg imagine the cost! lol
  12. profqwerty
    2 Jan 2006
  13. studentgaza
    studentgaza What's a Dremel?
    4 Sep 2008
    my cousin used 2 have that dryer and he had an adapter thing that went on the front which allowed him 2 put a normal dryer hose on
