Apple Mini Disc support?
Discussion in 'Software' started by unrealhippie, 20 Oct 2006.
  1. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Hey, little advice needed.
    Ok so I have a mac mini with itunes and a load of albums.
    I have a Sony MiniDisc player too, is there any way to get the songs from itunes to the minidisc within OSX?
    Cheers!
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Just play and record from your line out, surely?
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Do you want to use the NetMD function?
  4. unrealhippie
    24 Jul 2004
    Yes! (netMD is the usb function right?)
    Dont want to have to go through playing all the songs instead of just transfering.
  5. Valo
    Valo Minimodder
    11 Aug 2004
    my friend has netmd player and afaik it works with macosx,
  6. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    I reckon the usb connection from the MD should work with your OS X. I suggest trying it, and googl'ing for it.
  7. antiHero
    19 Jan 2005
    After some research i have to say that there is NO chance in getting songs from itunes strait to your MDplayer. The songs on itunes are MP3 for the most and Sony`s NetMD uses ATRAC3. Sorry but you have to use sonys program for that
  8. TheSaladMan
    TheSaladMan What's a Dremel?
    15 Sep 2006
    I swear I remember an old run of Apple ads on TV that touted the mac's awesome MiniDisc compatibility.
