Displays Mini-DP to DisplayPort 1080@144hz
Discussion in 'Hardware' started by pete*, 3 Apr 2018.
  1. pete*
    pete* Something witty here.
    29 Apr 2009
    Hey Guys,
    I’m trying to find a good mDP-DP cable that will work with 144hz guaranteed.
    I’ve looked on the DP site for certified ones but can’t find one from UK stores.
    Does anyone have a recommendation of one I should get? That definitely supports everything it should(DP1.4 if possible).
    I’ve had this problem with HDMI cables before and sick of so many crap cables. Best one ended up being a £4 off eBay.
    Thanks
  2. Guest-44432
    Guest-44432 Guest
    pete* likes this.
  3. Guest-44432
    Guest-44432 Guest
    Just to add - Display 1.2 and above supports 2560*1440@144Hz
    pete* likes this.
  4. pete*
    29 Apr 2009
    Cheers TG!
    Just needed info on one that is actually good!
    Bought. :)
    Guest-44432 likes this.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    EDIT - Bugger mis-read question
  6. Guest-44432
    Guest-44432 Guest
    As long as you haven't ordered a cable that's more than 2m, then you shouldn't have any trouble. :)
    pete* likes this.
