Motors mini hood scoops
Discussion in 'General' started by Froggy, 9 Aug 2003.
  1. Froggy
    Froggy New Member
    10 Jun 2003
    ok im looking to put a miniture ram air hood scoop on the top of my case. my problem is that every scoop i found is twice the size of my case. my plan is to mount a scoop on the top of my case, paint it blue to match my case, and put a 120mm fan in it. i cant find anywhere with mini scoops. the only thing i can think of is to get one custom made but i have no idea where to go. anyone know anywhere i can get a scoop? BTW the width of my case is 8 inches/ 20.5 CM.
  2. SiMonTiST
    SiMonTiST New Member
    14 May 2002
    Ever thought of putting one on each side?
    That would give the case a sorta jet-fighter look :D
  3. penski
    penski BodMod
    29 Aug 2002
    Use a NACA duct.
    *n
  4. Ubermich
    Ubermich He did it!
    21 Jun 2002
    /me thinks you should do something like the old chevelle (I believe) cowels that popped up when you gave her gas... rig it to pop open when you turn the system on... vrooooom :D
  5. Johnny Napalm
    Johnny Napalm New Member
    25 Jul 2003
    Why is this 'geek' thread in the motors forum ? ;) :p
    If you really want a mini-scoop go to a local sheet metal fabricator. Just draw up what you want with sizes, etc. and get them to manufacture it. You can always get it powder coated or paint it yourself to match your case.
