Motherboards Mini ITX/CPU Cooler Combinations
Discussion in 'Hardware' started by tp148, 25 Nov 2012.
  1. tp148
    tp148 Minimodder
    17 Nov 2009
    @GuilleAcoustic, thanks for that link, I already actually have that XMS3 but I will see what that other stuff looks like.
    @bindibadgi: 55W, going i3 ;). If you refer to post #10, you'll see the reason I intend to avoid the stock cooler! :)
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Have you used one of the new Intel stock coolers? I was pretty impressed with the newer models, not nearly as bad as the LGA775 models and previous.
  3. tp148
    tp148 Minimodder
    17 Nov 2009
    By newer do you mean 1156? or since the release of 1155. Because my 1156 one is not satisfactory and that was inside an acoustically insulated desktop case and i could hear it.
    So let's not forget that we are discussing one for a HTPC.
  4. BeauchN
    BeauchN Modder
    5 Apr 2011
    No problem, always happy to help if I can!
  5. docodine
    10 Feb 2007
    I've used the LGA1155 and the LGA2011 one, both better than I expected
    You can turn the noise down in the motherboard settings, for higher temps
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The LGA775 stock cooler I have seems almost identical to the LGA1155 stock cooler I have.
    Depending on the CPU you have, you will likely be able to turn down the speed of the fan as already said. The G550 I have in a system stays at around 30C at a fan speed less than 1000rpm. The fan is almost silent -- it's only audible in a very quiet room.
  7. RocketPotato
    RocketPotato What's a Dremel?
    4 Sep 2012
    Hi,
    I have a P8Z77-I Deluxe with a Noctua NH-L12 and it was perfect :)
  8. tp148
    tp148 Minimodder
    17 Nov 2009
    "was"? what happened to it? ;)
    Does that cooler interfere with RAM slots or PCI slot on that particular board?
    Thank
  9. RocketPotato
    4 Sep 2012
    I still have it :)
    The cooler is perfect, it does not obstructed any of the DIMM slots providing you use low-profile RAM (so not Vengeance). Its also using a GTX670 with no problems caused!
