Small Form Factor Mini ITX HELP,
Discussion in 'Hardware' started by wgy, 2 Oct 2008.
  1. wgy
    wgy What's a Dremel?
    28 Jul 2008
    Aloha.
    I am currently intrested in building a small mini-itx system, but alas, i know nothing about this format.
    My main aims for this project is to build a custom case for a system i can use primaraly as a jukebox / download box amd internet use. something small and energy efficient.
    I custum built a (high end a year ago) gaming rig, which doubles as my work (Adobe CS3 suite) computer, so im not clueless on ATX systems, but mini itx is something i have tended to ignore due to a bigger is better mentality- soon to change. :)
    ANY help, would be much apreciated. such as costs, brands, or factors i should look into. Thanks in advance.
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
  3. wgy
    28 Jul 2008
    yup, found this site just after posting.
    Forgot to mention, i have a tight budget, it might be impossible, im hoping for something under £100 GBP
    will keep looking, but any recommendations would help.
  4. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    you may have heard the name Atom here and there, intels atom is ideal for the type of machine your looking to build. The CPU is intergrated into the motherboard and costs about £60 you'll need to add memory ~1GB should be fine, and ideally a laptop HDD, and maybe a laptop DVD drive because they draw very little power, and the size is ideal for ITX.
    one draw back with the Atom is its onboard network controller, limited to T100, but the empty PCI slot can be used for a decent NIC or wireless card. Oh and atom is passively cooled which is a bonus! :thumb:
  5. fathazza
    fathazza Freed on Probation
    20 May 2002
    atom is the way forwards price and power consumption wise...
    tho you can get mini-itx boards with intel/amd sockets on them, although they tend to be more expensive.
    http://www.mini-itx.com/reviews/atoms/default.asp?page=1
    good round up of the latest crop of atom boards here, including an amazingly electricity frugal msi board and a dual core intel atom board :)
  6. wgy
    28 Jul 2008
    oooh, thanks very much.
    Atom seems to be the way forward then. will continue to look into this, and possibly create a project log if i custom build ther case. :)
