Electronics Mini-ITX + Laptop
Discussion in 'Modding' started by tech3312, 17 Apr 2007.
  1. tech3312
    tech3312 Where's my dremel o.0
    1 Apr 2007
    Hey people i need help i need a decent battery yet a inexprnsive one. one with a good AH or one that will run a mini-itx for about a hour with a charger. Next it is going to run the MIni-itx motherboards, two hard drive and if possible a 12 Volts monitor in u can't get one good enough for a 12 volt monitor don't fret but i suggest it an inverter that increases the voltage a buit will do thanks
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    One of these?
    That will give you 4AH @ 12V then you can use an ITX PSU convertery thing to get the other voltages.
    Like this or this
  3. tech3312
    1 Apr 2007
    i'm using the PICO PSU 120 Next the battry is like this the problem is i need anonine scematics for the battery charger. Nent can 6 RC 7.4 12000MAH (total) support this? i just need 1.2 hour morethe better and I NEED A SCHEMATICS
