Build Advice mini-itx
Discussion in 'Hardware' started by SeT, 23 Sep 2009.
  1. SeT
    SeT What's a Dremel?
    7 Oct 2003
    My old file server finally bit the dust. Surprised at how long the old Athlon lived though.
    Anyway, I'm looking at going mini itx in its place. I'm just having trouble finding definite answers for a couple things.
    1. Will a mini itx board fit easily into an atx case? I'm just going itx for the lower power consumption and the fact that I can just get the board and not worry about video or processor. I don't care about the amount of space the case takes up. Size-wise, it will obviously fit but I'm curious if modding will be required/new stand-offs placed.
    2. Will I need an itx psu? It looks like the same 20 pin connector to motherboard. I'm probably over-thinking this one but if I'm not swapping the case, no need for the smaller psu...
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Most cases will take an itx board.
    Standard psu's work fine, it's only nano-itx & pico-itx that have funny plugs
  3. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    1) If it takes an ATX board, it takes a Mini-ITX board. The four mounting holes that mITX uses are in the same location relative to the I/O shield and expansion slot as the four respective mounting holes on an ATX board.
    2) Standard PSUs are acceptable, yes, but if you're looking to get lower power consumption out of your system, you might want to make sure you have a very efficient PSU to go with it - otherwise, you're kind of defeating the purpose.
    - Diosjenin -
  4. SeT
    7 Oct 2003
    awesome. thanks for the replies.
    I'm not sure about my power supply except that the brand is xion? it's much newer than the rest of the system, would assume it's ok. Maybe when I have the cash to condense my 4 hard drives into 1 larger drive I'll move to a smaller psu/case. For now, I'm sure just dropping the power hungry athlon xp and ati radeon video card(this was my game box about 5 years ago) will lower consumption...
  5. KreCi
    KreCi Mini ITX Fan
    29 Sep 2009
    I have such server at home build on Epia MII12000 with passive cooling (custom made by me :D ). It is really silent and great choice for home server. I do not see it is working 24h/day on my electricity bill.
