Modding Mini itx
Discussion in 'Modding' started by rewris, 29 Oct 2003.
  1. rewris
    rewris What's a Dremel?
    21 Oct 2003
    why do mini itx boards have built on cpu's I want to make a mini pc with a mini itx board but those cpu's that are built on are so slow, do they have ones that you can change the cpu like a normal atx
  2. fonts
    fonts What's a Dremel?
    29 Oct 2003
    not that i have seen
    but if you find any
    let me know
    fonts
  3. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    You could always go for a Mini-atx. Not as small as m-itx. But at least you can change the CPU.
    Try here Linky
    Just search for matx you will find two there...
    or this one from ASUS .
  4. fonts
    29 Oct 2003
    that asus one is the one i have
    its nice
  5. Sid
    Sid Banned
    13 Mar 2002
    There was a thread a day or two ago about this. There are pentium 4 mini-itx boards, but no AGP slot as far as I'm aware.
    Have a look here. Fourth one down.
  6. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    mATX actually stands for microATX not mini, btw.
    there are indeed miniITX p4 boards. i've not seen amd ones yet, although heat would probably be an issue (then again fast p4s arent much better these days)
  7. Cyberbob:-)
    16 Jun 2002
    I know. I meant to go back in a edit it before anybody saw it.....
    Damm to late!!!! :D
  8. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Heh. Yeah, that was my thread. Still looking for a micro ATX with onboard video and Digital sound. :(
    As for that Asus one, there is actually a better one out now. Same size but is a minuature of the A7N8X. Can use a 400 mhz FSB processor, still has everything built on, has GF4 too, not sure if the 266 has GF2 or GF4. Anyway, its a little bit better.
  9. mrplow
    5 Sep 2001
    By digital sound do you mean spdif / optical?
  10. Cyberbob:-)
    16 Jun 2002
    What model is that ASUS one???
    Sounds interesting....
    **EDIT**
    I've found it, it's the A7N8X-VM isn't it??
  11. Solarius
    3 Oct 2003
    Yes.
  12. Solarius
    3 Oct 2003
    Yes.
    (Not a double post, but prolly should have combined them.. doh)
  13. ITX Warehouse
    ITX Warehouse What's a Dremel?
    7 Apr 2004
    We have the Insight P4-ITX Mini ITX that takes your standard P4 CPU's and the cases to go
    :thumb:
    ITX Warehouse - Specialist online retailer of Mini ITX products
  14. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
  15. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    I didn't read the whole thread, kinda lazy at the moment, but if you want a mini-itx board that you can change the processor with heres a p4 board that you can http://www.mini-itx.com/store/default.asp?c=2#p261 its at the bottom, heres a lil pic.
  16. ClearCaseMan
    ClearCaseMan Acrylic GOD
    13 Apr 2002
    shuttle makes itx boards as well
  17. SJH
    SJH Minimodder
    24 Dec 2003
    Shuttle motherboards are slightly different to ITX boards and are a lot harder to get hold of on their own without being part of a Shuttle barebones system.
    -Sam
  18. ClearCaseMan
    13 Apr 2002
    actually they ate itx boards and quite easy to get with out being in a bbsystem, try a dist like ingram with the htpc's I have sold I used fv-24 boards and they were not expensive it is the same board sold in the sv-24 (which is not available now) but amd and p4 boards are readily out there
  19. kenshin
    kenshin Banned
    22 Feb 2004
    You can get a shuttle barebones for the prices of those mobos linked :eyebrow:
  20. Captain Slug
    25 Nov 2001
    Yeah, but the machine I built with this board can fit inside a shuttle barebones and the machine itself weighs several pounds less. And in my opinion it has far more features and is more reliable.
