Case Mod - In Progress Mini Mod - Project Hand Baggage - Finished 27th April
Discussion in 'Project Logs' started by weeman1985, 7 Apr 2011.
  1. weeman1985
    weeman1985 What's a Dremel?
    30 Nov 2010
    After the tragic breakdown of my laptop I was left with no computer for my travels around the world. Soon I will be off to work in Turkey and I need some form of PC to keep me entertained and to stay connected to the world. Back in 2004 I bought myself a computer with an AMD Athlon 64 3200+ and ATI X800 GPU and was thinking that maybe that could be brought with me as hand baggage. I went back to my parent’s house, where it was stashed, and saw the size of the case I had bought for it. The Cooler Master Centurion.
    It was just far too big. I needed something smaller. While thinking of a solution to this I was also thinking of how to improve on a Socket 939 motherboard without spending too much money. After asking for advice on the Bit-tech forums I got an X2 3800+ and a new graphics card. They told me to get an ATI 5450 but I got a 1GB GDDR5 5670 from a friend for next to nothing.
    So new bits, still no case. On returning home to Italy my girlfriend told me she still had a computer that she bought in 1996 and that I could use that case. Before even looking at the case I measured it up and realised that it was perfect for flight hand baggage allowance. Awesome. So here is the beige goodness:
    Just as ugly as I remember computers being back then. Oh well, beggars can’t be choosers so time to take it to pieces. Also, sorry for the low res pics to start, this is the girlfriend’s parent’s house and I forgot my camera, so the PC webcam had to suffice.
    Wait a minute, what’s that? :jawdrop: A fold out removable motherboard tray? A removable hdd caddy? I could not believe what I was seeing, I really did not know that this was available in a case from 1996! It seems that the Millennium Bug really did have an effect on computers, the case got better paint, but worse management. Anyway, here it is in more pieces:
    That’s two removable side panels, fold out removable motherboard tray (with holes), the case and the HDD caddy. Time to do some cutting.
  2. weeman1985
    30 Nov 2010
    I picked up a 180mm fan for another mod idea I had but now that I’m moving again a desk mod doesn’t seem too clever, so time to give this case a real intake fan. First up was cutting the front plastic panel to accommodate the fan:
    I also cut a smaller hole for a usb/firewire/audio front panel that I took of the Cooler Master case. Now the test fit:
    They fit perfectly! OK, I’m not surprised. To get this I was outside filing and cutting for 5 hours. This being my first time doing this properly and wanting a perfect fit I worked very slowly, but in the end I am very happy with the results.
    Next up was thinking of a new place to put the power plug. I also took another part off the Cooler Master case, the power button section which also included the reset switch, and power and HDD activity LEDs.
    And a rough mock up with the buttons inside:
    They actually fit perfectly, another two hours of work. The other holes are for the fan speed controllers. The Scythe CPU cooler I am using has a fan speed knob as does the 180mm front intake fan, so they will be fixed here. The piece of plastic used for this was one of the 5.25” bay covers and it will be position in the middle of the three available slots. Between a DVD drive and a Soundblaster Audigy 2 ZS breakout box.
    That’s it for now, more coming very soon.
  3. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    woot. another project!
    Interesting goal. Are you planning on making it smaller? As far as I know, the Centurion is about the same size as this beige one.
  4. weeman1985
    30 Nov 2010
    I measured my Centurion back in the UK and off the top of my head it was something like (W) 210 x (H) 440 x (D) 500 mm which was just a little too big for hand baggage. Also it weighs something like 7 or 8 kilos with nothing in it!
    This case is (W) 190 x (H) 400 x (D) 400 mm and weighed 8 Kilos with the old computer inside.
    So luckily I don't have to make it smaller, just cut it to accommodate all the bits I want to keep my hardware cool but run relatively silent.
  5. Razer2007
    18 Jul 2010
    On OK. Nice man.
  6. weeman1985
    30 Nov 2010
    I found some paint in the garage that was a nice red and decided to paint the side panels. With only two coats at this point look at the awesomeness:
    Very Italian, especially with the beautiful espresso cup. Unfortunately, the paint ran out at this point and no one could remember where the spray can was originally bought. This could be a problem, more on that later.
    Anyway, time to start cutting, first up was marking out the holes for the fan air intake with an Ikea pencil. This is possibly the best pencil I have ever used for drawing on any material. Seriously.
    Front hole for the 180mm fan marked up with screw positions.
    Hole marked out for a 120mm exhaust fan. No screws for this one as they don’t fit, the fan fits perfectly with friction, will have to add some double sided tape to secure the fan and prevent vibration noise though.
    I am no metal cutting expert and was not sure which of the girlfriend’s father’s tools (what a mouthful) to use, I didn’t want to ruin his woodworking tools. So I had to wait until the next day for him to come back from holiday for some help.
    On his return he was more than enthusiastic about helping, and being an expert metal and wood worker almost had both the holes cut by the time I’d been to the toilet and made a coffee. I'm not complaining though! I did manage to get back in time for some pictures of the work in action.
    Apparently his metal disc for the rotary cutter was broken so he did all the cutting by hand using right-handed metal scissors.
    Front hole roughly done with the tools required for smoothing the edges.
    Offcuts.
    Here he is filing the back hole. I should say he is a perfectionist so the results of this hole were beyond my expectations. He cut so well it actually looks like it was part of the original design.
    Very nice! So cutting done, next up, painting.
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Good start man!
    Nice fan on the front side :eeek: but why did you chose to place it externally a show also the fan's "body" ?
    Ciao :)
  8. KidMod-Southpaw
    28 Sep 2010
    What aren't grandpas good for? Looks great! Nice update.
  9. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    i used that exact case for my last project. it was ahead of its time on features for a mid 90's case to be certain. i removed almost all of them however... i placed a 120mm fan in almost the same spot, and was able to use screws to bolt it on. nice shade of red. if you're going to match the plastic to it, you should try to find vinyldye in that shade instead of paint. you will get a better result.
  10. weeman1985
    30 Nov 2010
    Grazie! I wanted the fan to also cool the hard drive(s) and fitting it internally would not have left enough space for the HDD bay, so it had to be on the outside. I will think of some sort of fan cover that makes everything fit together nicely, as well as protecting my fingers.
    Also, you live in Italy right? Where do you get specific computer components? Qui in Torino non si trova niente! E in Mediaworld non vendono niente.
    Unfortunately for him he is not a grandpa yet, though he can't wait! He is good at what he does though...
    I'm still surprised by the case. I can't get the screws in for the fan as I've left most of the back intact so there are two rivets that get in the way, and I didn't feel like drilling them out and fitting new ones in a different position. Time constraints do annoy me sometimes.
    Good advice for the plastic painting, I will bare that in mind for next time. I've already painted everything that needs to be done to the best of my ability using acrylic paint and the colours match pretty well, but I see what you mean. Next mod will definitely be focussed on perfection, I really want to get one right that makes me go :rock:
    Painting update coming soon...
  11. Dragonite
    Dragonite Minimodder
    15 Feb 2011
    I don't know what you have access to but you could make a frame of plexi-glas or material of your choosing on the outside that you attach to the front plastic and then use plastic padding to smooth out the edges and then paint it so it looks like it is part of the frame.
    If you go to about 16:15 you will see something like what I'm thinking about:
    Though instead of the round fan duct Bill Owen is using you build a square frame for the fan and then you just use whatever fan grill on the outside when it's all done or attach it in the frame from the start.
  12. weeman1985
    30 Nov 2010
    Excellent, I knew there was a way to do it nicely. I will try that when I can get the materials and see what happens.
  13. weeman1985
    30 Nov 2010
    As I mentioned before, no one could remember where the can of red spray paint was bought. So we bought two more with what was the same colour. At least we thought it was. The paint colour code was exactly the same but the new paint was more red than the previous and did not leave a finish as naturally smooth. This being my first time spraying where the final finish was important this was not as I wanted, as I also have very little experience sanding. No amount of watching The Mod Men youtube channel for tips is going to beat experience, and given that I have a lack of time surround the build of this mod I wasn’t going to start now. I decided to just spray and see what happens after the paint cures.
    I decided that the inside of the case and the back should be black, with the top and side panels red and leaving the giant fan white. I didn’t really have a theme in mind, just decided that would work. Here is the front usb panel, HDD caddy, motherboard tray and inside side panels in black after the first two coats.
    The case, upside down showing the two fan holes nicely.
    Time for some red:
    I genuinely have no idea how I managed to get so much paint on the newspaper and not on the panels! I made a mess! I’m sure I could have got away with just one can for the whole case if I could actually paint. More practice needed I think. Above the side panels you can also see that I decided to do one side of the motherboard tray red. It wasn’t a real decision, I ran out of black. In the end it actually looks really cool.
    Some slight unevenness with the paint coverage. Was fixed with the next coat, but by then the battery had gone on the camera so no more pics. My girlfriend did however get a nice picture of the dog watching me work:
    OK, so not really watching, but he is called Lord Byron after all, and what Lord actually watches his minions work.
    I am off abroad for a couple of weeks on Monday so I will try to get everything assembled tonight to show off my first attempt at cable management. This is going to be especially fun as I am using an IDE hard drive and DVD drive, and am going to connect an FDD floppy disk drive. Also there is an IDE looking cable that connects the PCI Audigy 2 ZS to the breakout box in the 5.25” bay. This will not help airflow if I don’t get it right. Any tips on this, please let me know!
  14. weeman1985
    30 Nov 2010
    After a brief trip abroad I came back and finished the “beast” (OK, so not the most powerful PC around but is good enough for now!). Check out the pictures below.
    Starting with the cable management. This being the first time I’ve actually tried this properly I had no idea how difficult and time consuming it actually is!
    Take a break, take a pic. Work in progress…
    And here it is resprayed and all done up nice. And just to remind you what it did look like:
    A big improvement I must say. The wonders of a can of spray paint!
    Unfortunately, after putting it all together it weighed in at 11.2kg :wallbash: Given that in the three flights I took in the past 2 weeks every airline seems to be acting very strict about the 10kg allowance for hand baggage this was a problem. So, after hours of cable management I had to remove the hard drive and DVD drive to bring it down below the 10kg limit. So they have to go in the hold and refitted on the otherside.
    Lessons learned:
    1. Make sure you have enough spray cans before starting. This caused more stress than anything else. If I hadn’t seen the colour of the test spray I would be even happier with the red I have now.
    2. SATA is the way forward. The ease of cable management and airflow benefits are priceless.
    3. Make sure you have enough time to let the paint dry to put a protective coat on the outside. I have already managed to scratch the paint. :waah:
    4. 10kg is not a lot for a full computer. Gives me an idea for the next PC, it must be under 10kg with everything (but I have to wait for Skyrim to be released to work out what I’m going to buy. MicroATX is definitely what I want :D)
  15. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    Looks very nice, I don't do much reading and only really look at the pictures XD But are you going to spray the front fan aswell?
  16. weeman1985
    30 Nov 2010
    No spray for the fan, will get (or make) some sort of grill for it though. It's not too clever leaving it that open...
