Guides Mini Mods: Custom Glass Spacers and Retention Screws
Discussion in 'Article Discussion' started by bit-tech, 12 Apr 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Fizzl
    Fizzl What's a Dremel?
    9 Jun 2009
    Nice demo. Not sure I've got space or budget for a lathe!
    If you are going to dive into larger tools it would be great to see a build your own water block article. Maybe even looking at manually routing vs build your own vs getting your design done professionally.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    There’s definitely going to be some of that in the future for sure. I do have a manual router so in theory I could do that, but if I’m honest I would just recommend doing the design work yourself and outsourcing the cutting work if you don’t have a suitable machine. It’s more than possible to do by hand, as quite a few folks on here have shown, but basic machining is fairly inexpensive these days as the tooling required to make a decent block isn’t that advanced.
    On the lathe front though, I implore folks to look into mini lathes as they’re fantastic. Mine’s quite a diddy option and very capable, I would imagine most don’t realise how small they can get whilst still remaining functional. Just ask @Nexxo for confirmation haha
  4. Cheapskate
    13 May 2007
    Nope. Not falling for it. I don't have space for even a tiny lathe.
  5. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    But we can dream...
    Great guide. I think you're going to need to to restart and adjust your design to include the brass spacer.
Tags: Add Tags
