Build Advice Mini monster required
Discussion in 'Hardware' started by donok, 24 May 2011.
  1. samkiller42
    25 Apr 2006
    You only need one GTX580 on a 27" Display. I have a 30" Display and my GTX580 destroys everything i throw at it, GTA4, World in Conflict, Crysis/Crysis 2.
    Sam
  2. donok
    donok Every Little Helps .....
    16 Feb 2011
    Really? What frames per second you getting ?
  3. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    What about this?
    £1200 and it should destroy everything you throw at it.
    The motherboard doesn't support SLi but you won't want 580's SLi'd in a matx case. You shouldn't need SLi anyway.
  4. donok
    16 Feb 2011
    Can't see that link
  5. samkiller42
    25 Apr 2006
    I don't sit there measuring FPS. I never get any lag or stutter, smooth as silk.
    Sam
    Bloody_Pete likes this.
  6. donok
    16 Feb 2011
    Max settings ? All eye candy ?
  7. meandmymouth
    meandmymouth Modder
    15 Sep 2009
  8. donok
    16 Feb 2011
    Try saving a screenshot. All I get is the scan log in page
  9. meandmymouth
    meandmymouth Modder
    15 Sep 2009
  10. donok
    16 Feb 2011
    I'll not be paying tax and free shipping so this is well below budget at £976. My budget was around £1500 before tax. I really like the black PCB of the z68 gigabyte boards. Also prefer corsair ax psu as all the cables are black. Corsair vengeance ram is defo not the look im going for. Hate the design. A reference gtx 580 would exhaust air out the rear so preferable if I go sli
  11. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    I'm probably a penny pinching misery scrooge but on the right day you can easily get 2x1TB Spinpoint F3's for less than that 2TB WD (probably only about 6-7 quid but a saving is a saving :D) other than that i'd be extremely happy to have that build there sir. Looks very tasty.
  12. donok
    16 Feb 2011
    Was trying to get a single drive to use with 40gb intel SSD utilising smart response. No idea if you can use multiple HDD with single SSD ?
  13. zulu9812
    zulu9812 What's a Dremel?
    21 Oct 2010
    Might I suggest this case?
    Lian-Li PC-V354B
    Take out the bottom HDD cage, fit the rad + fan from a Corsair H60 in place of the bottom front fan, pair it with a Sapphire 5850 Extreme and you have the start of a great machine. The case has USB 3.0 and a built-in fan controller.
  14. Throbbi
    10 Sep 2009
    *Facepalm* Good point, moving right along :lol: Although i would be fairly sure that that price could be beaten for a 2TB HDD.
  15. donok
    16 Feb 2011
    Really like the define R3 case and happy that's it's not a full size tower. Nvidia would be my only choice for the graphics.
  16. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Out of interest, why are you so hung up upon the looks of the stuff, if you then insist on getting a case with no window? Unless he has the side panel off regularly no-one's going to see it?
    My 2 cents thrown in, I'd build an MATX rig based around an i5 2500K, 8GB RAM, Asus P67M-Pro (or Z68 equivalent), a GTX580 and a decent sound card (Xonar D2?), then stick it all in a Da Box 100. That won't dominate the room at all - no more than a large shoebox really.
    Should come in at less than £1000 without VAT.
  17. jasonst888
    jasonst888 What's a Dremel?
    24 May 2011
    Why the H50? H60 is better for about £10 more? and the h20 620 is better and its cheaper!!!?
