Mini-Project: Bench PSU *Update Mar 5th*
Discussion in 'Project Logs' started by mattthegamer463, 1 Feb 2007.
  1. mattthegamer463
    26 Nov 2004
    Hey, I just started a new mini project a few days ago to replace my aging 120w modified ATX PSU that I was using for testing items requiring molex power. I got this nice 200w AT model that I had no use for, and it has a fair amount of room inside for switches and things so it fit the bill. List of mods being done;
    -Mounting toggle switch
    -power indicator LED
    -Wire terminals
    -Molex mounted in PSU case
    -possible paint if it needs it
    -possible window (and therefore more LEDs)
    So far I've ran into a few snags. Radioshat had a nice little set of wire terminals I thought, but when installing them they kept coming loose from the case when I tried to turn the plastic tops, and while super-tightening them one of the bolts sheared off at the base. Then later after wondering why the PSU wouldn't turn on anymore, I find out that the terminals all are shorting to the PSU case. Apparently they aren't made for being mounted in metal, but that was never written on the package, and it said they were insulated. I may be able to fix this problem with some larger holes and some hot glue though.
    Other than that everything has gone well. Nearly wore out my needle file set though making the molex holes fit perfectly and be rectangular.
    ^ Trimming the wires back and discerning what I do and don't need.
    ^ Poor-quality terminals (before being broken)
    ^ The molex holes nicely cut out
    ^ PSU reassembled for a test
    ^ Molex connectors held in place by friction, I'm not gluing them in until I decide about painting the case.
    ^ Just another shot.
    Since then I've added a green LED right above the toggle switch in a small LED holder.
    More updates soon!
    *PS* Thoughts on a colour?
  2. mattthegamer463
    26 Nov 2004
    Update
    All done this mini project, for now.
    ^ Priming the case for black paint.
    ^ Painted black, assembling components.
    ^ another shot.
    ^ Squishing everything in, molex connectors mounted across the top.
    ^ All done.
    ^ Turns on! a bonus.
    ^ 12v terminal works...
    ^ ...and the 5v!
    ^ Break out the good-bad camera for this!
    ^ The money shot.
    And thus concludes my mini bench PSU project. I now have a power supply perfect for testing fans and other computer components without tangled dangling wires everywhere.
  3. spacemunkee
    spacemunkee What's a Dremel?
    17 Dec 2006
    Thats a really good project and a very well thought out idea for what it is. Definitely would come in handy i know that for sure. Top stuff :)
  4. Guest-23315
    Guest-23315 Guest
    Did someone say Ghetto ???
    No, just yanking your Chain. Nice little tester, and you have the added bonus that it actually works.
  5. JazX101
    JazX101 What's a Dremel?
    27 Jun 2004
    Lo!
    Got somethin quite similar, find it to be about the most usefull thing on my desk besides clear space (which is worth it's weight in gold) and my soldering iron. Only thing that kinda bugs me is when I'm being careless and drop one of the power lines and it shorts against the case.
    Great mod dude, v handy.
    Jaz_knos
  6. mattthegamer463
    26 Nov 2004
    Thanks all for the great comments! :thumb:
    Mine has a solution to combat this problem. The paint is non conductive, so unless the wire touches the bottom of a relatively deep scratch, it can't be shorted out. Funny how some things find other uses you hadn't thought of previously.
  7. r0z|3o0n
    r0z|3o0n What's a Dremel?
    28 Nov 2004
    Nice project, I have something similar only without the paint and the LED's and the tidyness, lol...
    1 thing I would/did change though... you left out the fun wires! Where's the -12v and -5v! Nothing better than a 12v fan running at 24v :D (Also with -12v I can power random pre-amp type stuff with it :D)
  8. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
  9. mattthegamer463
    26 Nov 2004
    Yes, your work sparked me to make a new one, because my old one was noisy and didn't work very well, and needed an update.
  10. Bluefan
    Bluefan test 123
    25 Feb 2005
    I just have 3 AT psu's lying around, gives more cable clutter, but works too :)
  11. mattthegamer463
    26 Nov 2004
    UPDATE
    I got a hold of my dad's Rebel XTi, so I took some nicer pics;
    I also came up with a plan to make some add-on components for it. The first one is a wire terminal box that connects to a molex connector. I made some garbage drawings in sketchup;
    The contact pads thing is for a modified voltmeter, so you can fine-tune the Rheostat to exactly the voltage/resistance you want. Also thinking about some sort of lock mechanism, so that you can lock the Rheostat in place so it doesn't move and change voltage. It will all be contained in a small project box.
    I will be scrounging up the parts I need in a few days. Comments?
  12. wbdog206
    wbdog206 not me
    15 Jan 2007
    that looks real good i think i am going to borrow some of your ideas if that is ok
    good work
  13. mattthegamer463
    26 Nov 2004
    No problem! If I didn't want my ideas to be used (or improved, for that matter) then I wouldn't have put them on the internet :D
    What ideas are you interested in?
  14. wbdog206
    wbdog206 not me
    15 Jan 2007
    thank you
    i like the way you mounted the molex connectors and added the screw terminals
    when i seen your mod i was thinking that would be a great way to control my wire mess on my work bench.
  15. mattthegamer463
    26 Nov 2004
    I came up with another Add-on box based on a molex connection. This one is an LED tester.
    The top row will be 2.1V, and the lower row, ~3.3V. Then it will be 10mA, 20mA, 30mA and 40mA across for each. Hopefully that will encompass most LEDs that I need to test. The wire terminals are for LEDs attached to wires, so you don't have to jam wires into the little holes.
    Thoughts?
  16. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
  17. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    U got some very cool ideas here , i would love to have a LED tester.
  18. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice work! :thumb:
  19. mattthegamer463
    26 Nov 2004
    Thanks for the comments. :)
    TapperSwe, the LED tester is going to recieve its power via a molex connector so that I can use it on any standard PC power supply, even one being used inside a PC! Just have to be careful about shorts.
  20. nry
    nry Minimodder
    1 Nov 2006
    Looks pretty cool. liking the idea of the addons
