Windows mini PS2
Discussion in 'Gaming' started by FaIIen, 19 Oct 2004.
  1. FaIIen
    FaIIen origami killer
    31 Dec 2001
  2. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Yep, its a tiny one. I have a family member that thought they were getting Playstation 3. I had to set them straight.
  3. copycatuk
    copycatuk What's a Dremel?
    10 Jun 2004
    they do look rather sexay :blush:
  4. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Don't Hotlink!
    Its been posted here before, but first picture I have seen with another object in the shot.
    'doc
  5. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    Yeah, they look good don't they?
    I wouldn't mind having one of those instead of my 'old' one.
    But I think the flip top lid kind of defeats the purpose, I can't for example buy this version and stick it in my very cramped rack space where the older versions would never ever fit becuase then I'd have to pull it out everytime I wanted to change discs :(
    They should have made it slightly thicker with a normal ejecting tray - it would have been much much better then.
    Just my opinion ;)
  6. Murdoc
    25 Jul 2003
  7. sheardjr
    sheardjr Minimodder
    7 May 2003
  8. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    wo ho, that they day I come back from Canada, so... I think I'll get that with GTASA... and impress my friends!!
    Now I'll just sell my PS2, its 4.5 years old, DVD doesnt work, Vibration doesnt work, memory card slot 1 faulty, doesnt always read disks..... blimey.
    However, does anyone know whether I can use network play on this new PS2?
  9. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Yeah, and apparently the network adapter is built in. :rock:
  10. MrWillyWonka
    25 Jul 2004
    P E R F E C T, my new look bedroom is gonna look so great with this...
  11. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    word of warning - not that 98% of people who own a PS2 care, or even if it's relevant in the UK, the mini PS2 does not, or will ever have, support for the hard drive addon. unless of course they release a USB version :p
    but by the sound of the sony press releases, they won't/
  12. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    Very impressive work, but one bad thing is that you can probably snap the thing into 2 pieces easily
  13. Murdoc
    25 Jul 2003
    coooooooommmmma
    That really depends if you use it to play games on, or as a primative snowboard.
    'doc
  14. MrWillyWonka
    25 Jul 2004
    or travel a lot
    As for the HDD, I am one of the 98% of people
  15. mushky
    mushky gimme snails
    24 Mar 2003
    I'm with you on that one. it is nice and small but with a flip top lid its virtually 4 inches tall if you are limited for space. Still, at that size you could probably tuck it away with your DVDs when not using it.
    That picture is a bit deceiving, even linford Christie's packet would look small against an original Xbox controller.
  16. Guest-16
    Guest-16 Guest
    My xbox controller has a completely different button layout!? I think its even bigger than the one in the pic?? :eyebrow:
    Flip lid does defeat the object but it is nice though.
  17. MrWillyWonka
    25 Jul 2004
    Theres two versions of the X-box controller, a big one and a small one - the small one from Japan, and everyone in the west liked it as it fit our hands better, so they brought it over here!
  18. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    There is a picture here that has a normal PS2 Dual Shock 2 Controller next to it as a size comparison.
    (you may have to click a link to skip an advert in order to see the picture)
  19. Guest-16
    Guest-16 Guest
    I must have big hands then, cause my "big" xbox controller fits mine perfectly.
  20. mushky
    mushky gimme snails
    24 Mar 2003
    The big ones fit fine in my hands as do the small ones. Though I prefer the thumbsticks and d-pad on the small one, they are much nicer to use.
    Bindi, that pic is of the big one. If your white + black buttons are below the coloured buttons and start and back are on the left then you have got a small one. controller. well, the smaller one. its still pretty big :)
