Scratch Build - In Progress ⭐ Mini-Splash, less than a Gallon water cooled SFF gaming PC
Discussion in 'Project Logs' started by Goatee, 8 Dec 2018.
  1. Goatee
    Goatee Well-Known Member
    19 Apr 2015
    Replicating the crimp? Nah. :grin: I could cut my own but I am lazy and prefer messing around building stuff, messing up and trying to figure out how to repair what I have done! Which is a nice way into;
    Update 13: Unlucky for some.
    As previously mentioned I decided to cut my vandal switch in half as it was marginally too long and I want to see how it works. It was going to be slightly difficult to undo.
    As you can see its a fairly basic operation, pressing the button at the front pushes an isolated piece of metal that makes contact with the two connections, triggering the motherboard.
    Here is my solution.
    * Bottom left - Is the cut down (to about half size) vandal body
    * Bottom middle - Is the original spring, I ended up cutting this down slightly given the reduction is overall length.
    * Bottom right - Part of a water cooling compression fitting I found it my bits box. It has exactly the same thread and size as the outside diameter of the vandal thread. :jawdrop:
    * Top left - This is the smaller replacement isolated "trigger". Its made of a rubber HDD idolater, nylon standoff and a screw. The original button is reused.
    * Top Right - A pair of terminals (metal standoff's) that have a small heat shrink sheath over the top. These are screwed into a piece of plastic the same diameter as the vandal body, they stick out slightly the other side giving to contact for the replacement trigger (screw) to to make.
    Here is my highly technical diagram. Press the button and the screw makes the connection. Let go and the spring resets the switch breaking the connection.
    And fitted:
    In hindsight I could have used smaller stand-offs or even just some screws passing through the plastic. This kind arrangement could then achieve a sub 15mm total depth for a vandal switch, but because I have 25mm to play with I just grabbed the nearest stand-offs I had, rather than worrying about it. I have become lazy with a whole 10mm to play with. A complete luxury compared to the rest of the build.
  2. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    Goatee likes this.
  3. Cheapskate
    13 May 2007
    That's a cleaner solution that a big blob of glue.
    Wait..Is that duct tape?
  4. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
  5. Goatee
    19 Apr 2015
    It’s a special temperature probe retention tape, rated extra sticky and with a sturdy level of hold.
    So yeah.
    Duct tape to hold the temperature probes down and isolate them from the case to ensure a good temperature reading.
    And because every good build needs a bit of tape also it’s not visible when assembled. Does this now count as an old school mod?
  6. The_Crapman
    5 Dec 2011
    I think the tape qualifies as ghetto, but a smidge of smudge is forgivable. My pci riser is insulated with kitchen foil and half a roll of electrical tape! :naughty:
    Goatee likes this.
  7. Goatee
    19 Apr 2015
    I am really pleased to have been nominated along with some other cracking builds for the Bit-Tech mod of the month modding update competition. Have a look here: Linky at all the builds and vote here: Linky if you fancy voting for me or any of the other builders.
    Update 14
    My updates have been slower recently, we have had a couple of issues with our heating in the house, some heavy snow and a bit of the illnesses that are always around this time of year.
    I have finally got the back panel on the case
    Its currently in place using the power of friction, but will eventually be screwed in like the other panels. Fits like a glove!
    Some money shots of the front, the simple, industrial look with exposed screws fits really nicely with the power switch I think.
    In case you cant tell, I like carter root beer! (other root beers are available)
    As a reminder here is the nice tidy front cable work:
    To do some stress testing (more to come on this in future posts) I stuck the undersized smoked panel in, again I really like the simple look.
    To keep the industrial look going, I think I might just lightly sand the aluminium and not paint it. I'm weighing up options though, so if you have any clever ideas then shout!
    _Prometheus_, Cheapskate and David like this.
  8. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Great job - I love it.
    Gets my vote!
  9. The_Crapman
    5 Dec 2011
    Congratulations on the nomination. :clap:
    I think metal is best left naked. It's what nature intended. Maybe go with heavier grit paper so the lines are a bit more brutal?
  10. Cheapskate
    13 May 2007
    The undersize panel looks like a perfect fit. :worried:
    I'd stay with bare metal too, and hit it with a sanding sponge until the edges were slightly rounded.
  11. _Prometheus_
    _Prometheus_ Active Member
    2 Jul 2017
    Perfect «Hand made». :dremel::thumb:
  12. Goatee
    19 Apr 2015
    Thanks Dave, super pleased to be currently highest voted update. I'm really surprised given the quality of other logs.
    Good idea, i like the sound of that!
    Its been cleverly cropped (even if I say so myself), its 6mm too short. Will look at rounding the corners.
    Thank you!
