Windows Minimum spec to run divx
Discussion in 'Software' started by fathazza, 2 Oct 2003.
  1. fathazza
    fathazza Freed on Probation
    20 May 2002
    im thinking about getting a laptop, which is a PIII600 with 320mb ram.
    Im just wondering if this is enough to play a decent res divx (eg, a 700mb dvd encode.
    for example one with a 608X256 res (just the first one i checked)?
    would this be alrighty? or would there be frame loss?
    also with the Speedstep thingy does this mean that it would be less likely to play when on the battery?
    cheers
    Hazza
  2. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    i have a machine playing divx movies just fine, and it's a pII 350, with 256MB SDRAM. plays as smooth as anything.
  3. fathazza
    20 May 2002
    sweet :D
    sounds good any idea on the speedstepping?
    + where abouts in bristol are ya?
  4. madhatter
    16 Sep 2003
    on the outskirts, a little village called Winterbourne - full of old people :/
    RE: The speedstepping thing, I dont think that'll affect it at all. I myself am using an XP-M processor on my laptop (which does the same - underclocks the CPU if not all being used) and that plays fine even with just 5% battery left.
  5. fathazza
    20 May 2002
    i know winterbourne a bit, when im not up at uni i live just (ish) past thornbury
