Miranda™
Discussion in 'Project Logs' started by Razor_cut, 6 Nov 2005.
  1. OldY
    OldY What's a Dremel?
    10 Mar 2006
    Can't wait to see this finished!!!
  2. Jipa
    5 Feb 2004
    Machine the heatspreader of that E6600 flat and I'll give you a buck ;)
  3. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I'll give you a cookie aswell. But I think lap sanding may be something to try. Anyone got a spare?
  4. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Give me the extra bucks if it brakes then I give it a try...
  5. ssR
    ssR Carbon God
    11 Aug 2006
    man this mod looks sweet!!! i guess there was no update for quite some time otherwise i would never miss it. keep up the good work man!
  6. sunnyg
    sunnyg What's a Dremel?
    18 Aug 2006
    yay another update. that is a really good idea with the cabling.
  7. Deejay2d
    Deejay2d What's a Dremel?
    31 Aug 2006
    Polishing
    This is turning out great. I love the blue plexi. My absolute favorite is the mirror finish on those fan busses and the DVD-ROM. I know it was already asked, and I know you said wet sanding, right? 800, 1200, then 2000. Then you used the Autosol? I found the stuff, but do to my lack of a bank account :sigh: , I am unable to order stuff. Is there anything comparable that I can get at a local automotive shop here in the States? I would love to get ahold of some of that stuff. The results are amazing! Keep it up! Can't wait to see this thing all finished up.
  8. customh
    customh conflagration.
    22 Oct 2005
    Beautiful i must say, keep it up.
  9. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    really nice work here man, keep it up :)
    glad you redid the gfx cooler, looks better now ;)
  10. Razor_cut
    12 Mar 2004
    Serched on google for you, have a look
    Memorycope
    An memorycope will hopefully be made in the coming days. I will turn the cope 180°.
    :thumb:
    I'm glad you folks like it :)
  11. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Hey Mr. Razor.. Nice to have you back =)
    Looking great, if you didnt know that..
    Will be looking forward to more updates :)
  12. Razor_cut
    12 Mar 2004
    Back in the place [2006-09-09]
    The bad metall has been rusty again.
    Will purchase something that fixes this problem.
    /Raz
    • Hardie
      As you can see.
      Motherboard found it's way to the lab
      What's your feeling in this?
      In the lack of screws, ironwhire works out fine :thumb:
  13. Razor_cut
    12 Mar 2004
    In the lack of muscle [2006-09-09]
    Looked for some rest on the suterdayafternoon,
    but look what I did instead :eek:
    • Triseps practise!
      Feels bad in the arms with the same movement done repetedly..
      [​IMG] [​IMG]
      [​IMG] [​IMG]
      [​IMG] [​IMG]
      Not a speciall nice look, but hopefully my
      hand look a bit better in normal conditions ;)
  14. Razor_cut
    12 Mar 2004
    continued...
    • Pollishing
      [​IMG][​IMG]
      [​IMG][​IMG]
      Fin
      :thumb:
      [​IMG][​IMG]
      A great workingplace!
      Gratzie!
      :thumb:
  15. Razor_cut
    12 Mar 2004
    woila :thumb:
    [​IMG] [​IMG]
    • [​IMG]
      Summer is over...
      Hope you find some inspiration :thumb:
  16. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    OMG that looks sooo nice with the polished hd's.
  17. chase
    chase What's a Dremel?
    11 May 2006
    Very nice polishing, would you mind writing up how you wenth through with sanding papers and polishing?
    Petter
  18. Jipa
    5 Feb 2004
    That poor VGA card looks pretty crazy with all those fans'n'ducts installed :D Some years ago ppl complained about two card-slots blocking coolers but now they are happy if there's any PCI-slots left free :) Great job with the polishing. I've used Autosol few times and to get such a great shine it is really time consuming.
  19. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Dude... I'm speechless... Pure image pr0n!
  20. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Sweet, but it lokks like you forgot to polish the acryl edges.
