Storage Missing Drive Space
Discussion in 'Tech Support' started by Pookeyhead, 4 Dec 2017.
  1. Pookeyhead
    30 Jan 2004
    Morning all!
    This is an odd one. I had this many years ago, and never got it resolved, but let's try again.
    Why have I got 100GB of missing space?
    As you can see... Windows reports 165Gb and WinDirStat reports 49Gb. With what's installed.... I'd expect around 50GB.
    WinDirStat is seeing the pagefile, so it's not that. Hibernate is off... and even so... 100GB? Although WinDirStat appears to report no user files, that's because they're not on C: Even taking this into account, make no sense, as "My Documents" is MASSIVE... it's clearly reporting that correct as 0... there are no user files that I know of on C:
    Help!
  2. Corky42
    Corky42 What did walle eat for breakfast?
    30 Oct 2012
    Are you running WinDirStat with administrative privileges?
    Does selecting all the files and displaying the properties tally with those you get when just displaying the properties of the drive?
  3. Pookeyhead
    30 Jan 2004
    I am, yes.
    No... opening C: and selecting all visible files and folders shows roughly the same figure as WinDirStat... around 49Gb
  4. RedFlames
    23 Apr 2009
    System Restore images? IIRC they show up as 'used' space, but don;t show in windirstat
  5. Pookeyhead
    30 Jan 2004
    Nope... got that turned off.
    Seriously baffled.
  6. RedFlames
    23 Apr 2009
    might want to run
    Code:
    vssadmin delete shadows /all
    just to be sure, iirc turning it off doesn't always remove old restore points.
  7. Guest-16
    Guest-16 Guest
    Use SpaceMonger 1.4 instead. Basic, old program, but always worked flawlessly for me.
  8. Corky42
    30 Oct 2012
    It's probably a permissions thing, WinDirStat and selecting all files > properties is most likely not listing a file or files you don't have permissions for whereas drive > properties does.
    You could try using AccessEnum from sysinternals and see if that turns up any VHD's or other large files that have been left over from when a program was uninstalled.
  9. Neilc
    Neilc Member
    5 Apr 2011
    Try TreeSize free edition and run as administrator. I use at work all the time and always bang on.
  10. Pookeyhead
    30 Jan 2004
    Yep.. that did it!
    For some reason, this folder "CSC" has copies of stuff on my server in there.
    Thanks for the help everyone.
  11. RedFlames
    23 Apr 2009
    run cleanmgr, that little lot should [iirc] show up as 'Oflline Files'
    CSC stands for 'Client-side Cache' and... well... you can probably guess what it is/what it's for.
    There is a way to turn it off... but can't remember how at this exact moment.
  12. Pookeyhead
    30 Jan 2004
    I know what it was. When I did this new install of Win10, the Sync App started running on my network drives... those files were just what it had synced as "offline" before I disabled sync.
    Mystery solved. :)
