Memory Missing RAM issue
Discussion in 'Hardware' started by Spanky, 28 Dec 2012.
  1. Spanky
    Spanky Minimodder
    14 Apr 2010
    Guys,
    Have just installed a new Agility 3 in the girlfriends computer, after the install im showing 4gb RAM installed but only 2 useable.
    CPUZ reports both sticks installed aswell. I cannot change the memory into the other 2 slots as cooler/height issue. Ive reset BIOS but no change.
    Has anyone experienced anything like this before ?
    Asus P55 LE 1156
    4BG Rpijaws 1600 2x2
    I5 750
    Any thoughts would be appreciated cheers.
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    What os is it?
    32bit or 64bit?
  3. Spanky
    Spanky Minimodder
    14 Apr 2010
    64bit
  4. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Check that the "Memory Remap Feature" is enabled in the BIOS.
    While your there, check if the BIOS is showing the whole amount.
  5. Spanky
    Spanky Minimodder
    14 Apr 2010
    The re map feature is enabled, tried the MSCONFIG and made sure the maximum memory is unchecked.
    Googling the problem seems to bring up the same board, many people with the same memory. I have another 4gb i can try when i get home. Strange problem and im sure the full 4gb was fine until i re booted today.
  6. Fat Tony
    Fat Tony Minimodder
    3 Jul 2009
    Have you run memtest86 ?
    take out - have a good visual check - and reinstall / reseat ?
    what's telling you that only 2Gb are usuable ?
  7. Spanky
    Spanky Minimodder
    14 Apr 2010
    In windows itself (right click computer) says 4gb but only 2 available . As its at the girlfriends house bit hard to do anything to it just at this moment in time.
    Real crappy problem!
