Cases mITX case with USB-C front header?
Discussion in 'Hardware' started by silk186, 14 Jun 2018.
  1. silk186
    silk186 Canadian
    1 Dec 2014
    With laptops dropping USB-A I'm wondering where are the cases with Type-A and C headers on the front. It doesn't need to be 3.1 but it would be nice to have the ports without needing to use a hub. Have any been released or announced?
  2. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    Do you really need type-C connectors on your case? I just use an A-to-C cable and it's happy days. Type-C connectors are pretty rare on mITX cases, in my experience.
  3. Anfield
    Anfield Well-Known Member
    15 Jan 2010
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    It'll be a few months yet, Type C front panel keystone assemblies were not available on the open market until recently, so cases could not incorporate them unless they developed the front panel assemblies themselves (not an easy task due to Type-C's signal integrity requirements).
  5. RedFlames
    23 Apr 2009
    Not 3.1 but Silverstone do this for their existing cases...
  6. silk186
    silk186 Canadian
    1 Dec 2014
    As I said in the OP, type C is going to become much more popular and will replace type A.
    Type A ports are disappearing from laptops.
    Apple is rumoured to be switching from lightning to type C ports.
    Mobile devices are moving from micro-b to type C.
    When USB 3 ports were new I made so to get a case with that supported it.
    I regularly use USB 3 thumb drives and external HHDs, I expect that same will happen with type C ports.
  7. silk186
    silk186 Canadian
    1 Dec 2014
    That looks perfect, few devices will saturate 3.0 speeds.
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I suspect we won't see many USB-C ports on cases until the new USB 3.1 motherboard header gains more ground.
    On the other hand, this IS a modding forum!
  9. edzieba
    14 Jan 2009
    From the spec sheet, there are some other interesting variants of the motherboard header: a "B key" version that breaks out into two Type A connectors rather than a single Type C (way more compact than the current USB 3.0 header), and a 'double wide' version that can support two Type C ports (but not 4 Type A ports).
  10. silk186
    silk186 Canadian
    1 Dec 2014
    Hopefully we see more 3.1 headers on the Z390 platform. The usb3 type C header is good enough for all of my future needs. If I really need 3.1 speed I can use the port in the back of the case.
  11. silk186
    silk186 Canadian
    1 Dec 2014
    Asus ROG Strix Z370-I Gaming has 1 x USB 3.1 Gen 2 front panel connector port(s) (Support 3A power output)
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    The pics on Asus' product page only show a 3.0 header.
  13. RedFlames
    23 Apr 2009
    It is there, hidden in the top left corner by the 8-pin power connector and rear i/o block... It's also powered by an ASMedia chip, not the intel chipset.
    EDIT:
  14. Anfield
    15 Jan 2010
  15. silk186
    silk186 Canadian
    1 Dec 2014
    I went off the official product page.
  16. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Ah! I was only looking at the front of the board. I didn't think they'd hide it over there! :duh:
    That makes modding a case much simpler. 3.1 to USB-C leads are much simpler to come by.
