Cooling Mk 26 WOW
Discussion in 'Hardware' started by lilgoth89, 25 Jan 2013.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    so i just picked up this cooler to throw onto my 7870ghz edition and WOW the perfomance is amazing
    ive a high airflow case ( Silverston RV02 ) and my idle temps are 24 degrees ( no idea what ambient temp is tho ) with an enermax vegas dual ( lets face it not the best fan on the market ) at its lowest speed ( and all fans in the case down at low on a fan controller ) and i get 62 degrees with load ( heaven benchmark )
    i might even have a stab at runinng the cooler passively to see what kind of numbers it kicks out
  2. Guest-23315
    Guest-23315 Guest
    I had a T-RAD 2 back in the day and it had the same sort of effect.
    They might be massive, but boy do they do the job.
  3. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Ah another satisfied member of the MK26 club :)
  4. David
    7 Apr 2009
    At £50 without fans, it bloody well ought to be amazing!
  5. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Agree 100%
    For the price of it, it really does have to be perfect. Thankfully it is :)
  6. lilgoth89
    12 Mar 2011
    decided to use the AMD baseplate of the cooler with mine so i had to dremel away some of the metal around the socket to accomodate the coolers mounting arms, and my dremel broke ( stupid cheepo one, so im not that upset ) so i had to manually file 3 notches and snap off a small bracket, all went well in the end and it looks and performs brilliantly, just need to source some more permanent fans ( thinking a pair of Sythe GTs )
  7. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    I'd recommend 140mm fans, as they move more air and are quieter than 120mm equivalents.
    My priority was quietness when choosing my fans anyway :)
  8. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Just a heads up, recently attached my MK26 to my GTX680 after selling my 580 and have been blown away once more.
    It idles at 20 degrees, and the highest temp reached at load is 50. That is the actual temp, not delta t! And all this while my 2 Thermalright 140mm fans are undervolted to completely silent speeds.
    The case is a Corsair 550D, which has 2 front intake fans completely blocked by my hard drive cage and PSU cables and such, and one rear exhaust. All 3 120mm fans run undervolted again, at a completely silent speed.
    The CPU is an overclocked i5 2500K with a Gelid Tranquillo cooler.
    I mean an overvolted 2500k inside a closed up case like the 550D with only one exhaust fan, and the GPU temps are still that low - just crazy :rock: Gratz to Prolimatech for being ridiculous.
