Modding mmmm... watercooled xbox 360
Discussion in 'Modding' started by SaII, 29 Aug 2007.
  1. SaII
    SaII What's a Dremel?
    7 Jun 2006
  2. radodrill
    radodrill Resident EI
    14 Mar 2006
    True; it's excellent work, but I don't like the fact that he used koolance waterblocks.
  3. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Koolance are the best choice if you plan to keep it in the stock case.
    -CollinstheClown
  4. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    good job, but its still an external solution
  5. radodrill
    14 Mar 2006
    I wouldn't go with Koolance for anything; IMO their blocks don't perform well; and not to mention their RADs are aluminum, resulting in a mixed-metals loop.
  6. Pie_uk
    6 Apr 2005
    are they alu? or plated? surely there not alu on the outside? they would be coated i would have thought. isn't that what zerex or what ever is for anyway?
  7. radodrill
    14 Mar 2006
    According to Koolance their RADs are aluminum. Most RADs are also painted on the outside to achieve a gloss finish. Sure Zerex/Pentosin (or any engine coolant) will reduce the effects due to corrosion, but it's not a cure-all; not to mention, the purer the water, the more effectively it performs.
    Also, IMO their blocks are crap.
  8. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    altough koolance blocks aren't the best it shouldn't matter as it's not like he's OCing the xbox 360 just Wcing it, the ultimate test is does it work? and it seems to, so stop drinking the hatorade.
    very nice work, but I'm not a fan of windows anymore but it is nice to show off that sort of workmanship
