Case Mod - In Progress mmt 900D Case
Discussion in 'Project Logs' started by arg-ist, 27 Jan 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    A new 900D case
    but these time with;
    MB : ASUS Z87 Sabertooth
    CPU: 4670 K
    RAM: G SKİLL 16gb 2133mhz
    VIDEO .: ASUS GTX780 DIRECTCU II GDDR5 3GB
    POWER: CORSAIR AX1200i
    CASE: CORSAIR 900 D
    RAD: 2 X Alphacool UT 60 480
    WB. CPU : Koolance 380i
    WB. GPU: EK
    PUMP: Swiftech MCP 655 With Speed Control
    RES. : EK-RES X3 250 Reservoir
    TUBİNG: Tygon E-3603 1/2" ID (3/4" OD) Clear Tubing
    FITTINGS: Monsoon Compression Fittings, 1/2" x 3/4" Single - Chrome
    FLUID: Mayhems Aurora Tharsis Red,
    http://www.youtube.com/watch?v=7iMmwNEua0E
    OTHER WORKLOGS
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
  2. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Why is this in the Project Log section? Nothing seems to be modded?
  3. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    comming soon...
  4. Meelobee
    5 Nov 2003
    Ah, it shouldn't be here then, but in the modding section I think;
  5. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    i can see a custom plexi panel and waterblocks on the graphics card, seems to me it is a project log, just missing some explenation of the text.
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    These is my 3.th 900D that I have build
    although CORSAIR 900D is a big case, but there are mistakes
    there is no middle plate at the case.
    I have build one, white plexi midplate
    as back plate I used original Asus backplate (modified)
    When 480th radiator is installed to the front of sub-part, there is 50mm space left except 60mm radiator+25mm fan.
    It is impossible to mount a radiator and fan together in this place.
    Even if a thin radiator is used, there is no place left to work and joining between radiators.
    There is no free place for pumps , you must remove HDD cages.
    If you remove hdd cases … the result.
    Therefore I made a plexi with Asus Rog logo.
    No one can say me that 900 D is an all in one case for watercooling
    Don t think ,900 D is a big Case for watercooling…It is a MINI – BIG CASE only…
    ,I think 900D was produced as a big case at first, later it has been minimized.
    I hope Corsair 900D V1 is coming soon…
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
