SketchUp MNPCtech & Bit-Tech.net case design contest #5 - (Deadline moved to September 1st)
Discussion in 'Modding' started by Roboduck, 1 Jul 2010.
  1. Cheapskate
    13 May 2007
    Now that you nix'd the hole, the heat pipe arrangement is odd.:D
  2. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    What's so depressing about the SpinQ? Just because it's mady be Thermaltake? Sure their cases are hideous, but this cooler looks great imo. Didn't even perform that bad actually...
    You might want to include some kind of mounting mechanism to avoid the cooler breaking the board in half. :)
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    well, the lower section needs tweaking still, and there are a few more features to add.
    I should probably sit back and actually plan this design, other than just 'playing around'. Not very good for someone who has a degree in design after all! lol!
  4. Cheapskate
    13 May 2007
    Mount the chip backplate to the mobo tray!:D -Oldest trick in the book.
  5. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Still might not have time to compete - project o² just kicked into top gear
  6. Burnout21
    9 Sep 2005
    hence why the tray is 3mm alloy, also the mounting fixings would have to engage from the back side as well.
  7. Cheapskate
    13 May 2007
    @confusis - Test drive the O2 hardware by building a contest submission.:D
  8. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    I tried something simple, let me know what do you think... also does it fit the "tortuous" theme? :worried:
    ps: great cooler burnout !
  9. confusis
    5 Jan 2006
    Problem with that is the case is still a fair bit away from being finished. I'm not a fan of running systems on the bench. That and I need a new monitor ><
  10. Cheapskate
    13 May 2007
    @Korben - I tried messing with my monitor settings, but I could still only see a black spot. You might want to switch the colors to a dark grey so we can see your build.;)
  11. k0rben
    22 Jul 2010
    Thanks Cheap for reply, here is the pic in chrome
    The idea its based on touchscreen connected to mini-itx board, located "in" the table.
    I can imagine this concept in museum or a gallery etc.
  12. Cheapskate
    13 May 2007
    Much better, Thank you.:D
  13. k0rben
    22 Jul 2010
    And what you guys think about that? :worried:
  14. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    i finally started to work on something :
    that's a 20" screen, i'll make a walking rendering farm :O that will be about 2m high and 4-5m long
  15. Cheapskate
    13 May 2007
    @Korben - OOPs. I'd go with the middle version. Putting anything behind the I/O plate ALWAYS causes problems. If it's a kiosk setup, you might want to make cover panels. (You have to expect trouble from the average brat or moo-cow.)
    @Dark - Well it's about d*mn time!:hehe: I thought I was going to have to hit you with a stick.
  16. Dark~3nergy
    14 Jan 2007
    mouahaahah soon it will take over the world :naughty:
  17. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    ^^ Reminds me of this:
  18. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    :eek: omfg, i think to small :(
    where on earth did you find that :naughty::jawdrop::thumb:
  19. Javerh
    5 Sep 2006
    Attila likes this.
  20. Attila
    Attila still thinking....
    22 Feb 2008
