SketchUp MNPCtech & Bit-Tech.net case design contest
Discussion in 'Modding' started by Dark~3nergy, 1 Apr 2010.
  1. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Oh snap, i need to get started! I have a plan for this, it may or may not fit the theme very well, but it's all about the process anyway!
    Great headstarts by Cheaps and editor by the way, as always :D
  2. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    haha cheaps, forgot to say that, but the model is 10x bigger then what it should. i always model 10x larger in SU, otherwise it breaks small sized faces.
  3. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    I always had that problem too and i really hated it, made me switch to max after all...
  4. Trance
    Trance Two steps forward, one step back
    6 May 2009
    Well this is what mine is looking like at the moment, still a lot to do, but you can now see it starting to take shape.
  5. Cheapskate
    13 May 2007
    Very tiny and red!(WTF did I just write?) If you built this in real life it would be packed solid with wiring!:hehe:
  6. motas
    motas What's a Dremel?
    7 Dec 2009
    That's what she said?
  7. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    Just soften the faces and the edges by 20-30 and it's all good after that.
  8. unknowngamer
    unknowngamer here
    3 Apr 2009
    I've had a brainwave.
    Based on a current bit of kit.
    "$%B+
  9. Dark~3nergy
    14 Jan 2007
    bentleya, it doesn't have anything to do with the smoothing. it's that SU can't handle faces that are smaller then 1mm by 1mm very well, so when you create curved surface it often looks horrible or some parts are missing
  10. lenne0815
    4 Jul 2009
    yeah, they just foobar and disappear, no way of making them coming back.
    Really annpying bug, especially considering it should make no difference at what scale one is drawing, as soon as u scale it up it works, huh ?
  11. Dark~3nergy
    14 Jan 2007
    here, just to show it :
    a curved tube made with a 6mm circle :
    same curved tube but made 10x bigger, 60mm :
  12. Mork
    Mork What's a Dremel?
    9 Nov 2009
    A SFF competition! :D
    I hope I'll get time to do an entry for this competition!
    Is there a special theme for the cases? like gaming, htpc or is it whatever one prefers?
    /Mork
  13. Dark~3nergy
    14 Jan 2007
    you can do it like you want, doesn't have to be a gaming pc, can be htpc, etc... you just have to use a m-atx motherboard :)
  14. confusis
    confusis Kiwi-modder
    5 Jan 2006
    just 1? ;)
  15. Mork
    9 Nov 2009
    Okay, thanks! :)
    /Mork
  16. confusis
    5 Jan 2006
    Quick questions:
    Is there a limit to the amount of m-atx boards we can incorporate into the design? And can we use custom design boards that don't exist? (as long as they fit to m-atx dimension specs)
  17. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Oo I go away for a day and there is so much to catch up on! seems like everyone's in again this time :)
    @ cheap - Excuse the ignorance but WTH is Betelgeuse other than a giant star? lol see your rolling out another cheapskate masterpiece :p makes me think of some sort of futuristic pill box for a space station :rock:
    @ Confusis - More than 1 matx? what you got planned :jawdrop:
    @ Metric - Nice to have you along for the ride dude.
    Not sure if I'll carry on with this or work up on a new idea.
  18. Dark~3nergy
    14 Jan 2007
    looks nice editor !
    confusis, if you feel like makeing custom boards and useing more then one,i don't think it would be a problem, just don't make a gigantic case :eek:
  19. confusis
    5 Jan 2006
    Describe gigantic ;)
    4 socket am3 cpus on one board is a tight fit with a pciex16 slot too!
    :naughty: :naughty: :naughty: :naughty: :naughty: :naughty: :naughty: :naughty: :naughty: :naughty: :naughty: :naughty:
  20. Cheapskate
    13 May 2007
    @confusis - :lol:
    @editor - Sorry, meant Beetlejuice.
    I say continue with the design, but try to make the base open like the top.
    Also- Check the filename for my project's name.:naughty:
