SketchUp MNPCTech Design Contest Volume 6 - Modify a Cooler Master HAF 932
Discussion in 'Modding' started by confusis, 16 May 2011.
  1. Cheapskate
    13 May 2007
    YOU must build it.
    Keep the rad.:D
    I thought I was done...
    I did some fluffing of the piggy.
    Is it obligatory that the cup holder gets turned into a reservoir yet? I also added some height to accent the odd shape.
    The insides show some issues with gpus and rad fans. I guess 120mm fans might fit. The HDs are removed through a panel in the back.
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Nice design, very 50's. Pink cadillac, and it makes me think of those old jukebox (I'd damn like having one).
    Maybe some beige leather here and there :thumb:
    A door coin as start button would be awesome
    I live your design a lot.
  3. GuilleAcoustic
    26 Nov 2010
    Something like this ? :naughty:
    It still needs some adjustment. But I think it can work.
    Highpoint Rocketraid card has a per drive led activity header. I'll check if it is available on all cards. I'm wondering if LSI or Adaptec have this feature too.
    EDIT : Or something like that
    Can be hidden under the HDD bay and still uses gear + worm gear for an effort less opening. Which one do you like the most ?
  4. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Yup looks like a winner to me =] holds up 2 3 mini kegs and a 4 pack
  5. Shael
    Shael What's a Dremel?
    19 Jan 2011
    :thumb: definately the 1st option i like the gears :) with a side window showing the movement of course for just that extra little bling factor:rock:
    With the gears method have you thought of taking it 1 step further? :idea: make the stepped motor with a dual action button with a secondry vertival movement.
    1st position: brings the door down to access the drives.
    2nd position: brings the door down so you can see the screen then moves it up so the drives are covered but can still see the display ;)
    If i wasnt at work I would quickly show you what i mean on sketchup but this pc is a celeron and doesnt like sketchup (yes i tired):naughty:
    thanks for the info on the raid cards Guille, just wish i had the time to do a quick sketchup of this case too....hmmm day off tomorrrow.....:idea:
  6. Cheapskate
    13 May 2007
    @grritsshawn- YOU CRAZY!:lol:
  7. GuilleAcoustic
    26 Nov 2010
    We have the beer, we have the BBQ :
    Let's the party begin :hehe::lol:
  8. Shael
    19 Jan 2011
    Nope have beer pc on the right and gaming pc on the right.......no need tog et up to get a beer:lol:
    Just need a vapor chill system to keep the beers frosty:hehe:
  9. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    :D BBQ one is the bast man!
  10. GuilleAcoustic
    26 Nov 2010
    Little update :
    Been working on the bigmuthafu Rad (thx Razer for the name :naughty:). I'll be using threaded quick disconnect coupling (the male ones connected to the back side of the top Rad / the female ones connected to the Rad).
    I still have to model the adjustable connector that will allow the female connector to horizontally translate to easily connect them to the male one (the same way than adjustable SLI connectors).
    The 2 white / grey tubes are nickel plated copper tubes that connects the bottom part to the top rad (Who said I do not like tubing in the middle of the case :lol::lol:).
    I'm wondering if I should leave the tod rad channel visible (via the ACETAL plexi cover) or if I should make a plain ACETAL cover (maybe it would be cleaner and more workstation like).
  11. Shael
    19 Jan 2011
    I would leave the top channel visable, with some uv coolant it could show :D of the channels nicely
    Nice work on the raditators gonna take a lot of work to make that and a lot of copper too
  12. Cheapskate
    13 May 2007
    Gawd! That would be a nightmare to bleed. :lol: -I should know. I've been running bloo for months with an air pocket in the cpu block.
    Acetal? Why not transparent aluminum? -Or uranium glass?
  13. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Apparently there is a transparent aluminium being invented. however it only becomes transparent under a certain type of light and reverts back to normal quickly :(
  14. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    Hi all this is my case, project Mantis (cos every project must have a name :p) i am submitting now, because im going on a holiday and i probably won't be back till june 30.
    The hole here is for PSU intake.
    sideview
    bottom-view - as you can see it has 2x480 rads,3x GTX295, 2 custom mounted res'.
    here you can see psu and hdd compartment, optical drive is optional ;)
    if you're asking how that comes apart, here is it - lift top, top then stays on opened position, since there is a hinge on rear. Then you can open the front.
    last one showing back.
    Sorry for this rather long post, im kinda dumb and left the final touches be, so if i'll make it to the 30, i probably will touch it up.
  15. Guest-23315
    Guest-23315 Guest
    I have yet again manged to miss another compo... :waah: But one day I will enter!
    (and that BBQ HAF deserves a prize on its own)
  16. Cheapskate
    13 May 2007
    @Korben - Whoa! dude. There's some freaky optical illusions going on with the faceplate. Placement of the fins makes the center look offset. -That's kinda cool.
    Like the little stabby bits coming off the back too.
    The loop setup has some issues, but this is about the case design so F it.:D
    @Mankz - If I remember, I'll PM you next time.:lol:
  17. GuilleAcoustic
    26 Nov 2010
    Almost final entry :D. I made a few modifications and changed the Rad holding for a cooling dock.
    The dock hold the rad and you place the case on the dock (thanks to "rolls"), secure lock it and plug the quick disconnect plugs at the back).
    I have to make some adjustment on the front door opening system and to add I/O and fill port
    Here are the pics :
  18. eeced
    eeced My finger is in the fan
    26 Mar 2007
    Air makes it so easier to breath than water, so I'm going for aircooling (that made no sence whatsoever). A case for two friends to drag (carrying probably not possible) to a lan party, a two in one computer.
    I'm uploading this now if I can't come up with a better look for the back of the case, it's a bit too flat atm. If I do come up with at better look I will try and fix that to tomorrow.
    Not sure if building a case like this would be practical, but I didn't see anything in the rules about the case having to be practical (or even possible) anyway. ;)
    The Front and sides (Saving bandwith by joining some pics)
    Top and bottom
    Side panel(s) open, other side of the case works the same
    Practical? Who cares?
    One 140mm exhaust fan seemed to weak
  19. Shael
    19 Jan 2011
    Looking Good there Guille :thumb:
  20. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Excellent work guys!
    Eeced - I see you've used a model I submitted to the SCC :p
    Guille - Thats insane!
    Cheaps - Crazy as usual :)
