SketchUp MNPCTech Design Contest Volume 6 - Modify a Cooler Master HAF 932
Discussion in 'Modding' started by confusis, 16 May 2011.
  1. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    That's the way to go ... crazy, insane, mad. I'd love to see an Halloween contest (or any other theme restrained contest : Space, Mythology, etc.).
    Only 2 days left ... lot's of work ahead :wallbash:
    EDIT : Thanks to everyone involved in this contest :thumb:
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Sorry I haven't been involved so much this time round, life again ><
    Also planning a new build so time has been spent on that.
    Oh Bill, if you read this, I sent you a PM on FB :)
  3. eeced
    eeced My finger is in the fan
    26 Mar 2007
    Yes I used some "ready" parts only to illustrate how I was thinking, if you prefer that I don't use it just give me a heads up. :)
    AMD Radeon 6970 by DanitGeek
    Thermalright Ultra 120 by Scooby
    MNPCTECh Switch Mounting Plate by Kylevdm
    Gigabyte GA-L78-LS2P by Confusis
  4. confusis
    5 Jan 2006
    The reason we upload it is so it gets used! Its a core part of these MNPCTech Design contests.. go for it :)
  5. GuilleAcoustic
    26 Nov 2010
    Did the power switch (the red one), door open/close switch (the blue one), 4x USB ports and 2x 3.5mm jack connectors.
    I've added a fill port directly built-in the copper top radiator
    EDIT : Just realized that I did erase the chassis instead of hiding it (fortunatly I can import it from a backup) :wallbash:.
  6. Cheapskate
    13 May 2007
    @eeced - :thumb: It looks ready to fly.
    @Guille - Numbered backups at major stages of the build have saved my butt more than once.
  7. danitgeek
    danitgeek Designer
    17 Sep 2010
    Here is my Finished Case Design
    The Haf Urban
    2 Psu Mounts
    9x 120mm fan options
    Atx/M-Atx/Itx
    Mountaing options for 2 reservoirs
    2x 2.5inch hard drive hot-swap bays
    2x 3.5inch hard drive hot-swap bays
    3x 3.5inch hard drive bays
  8. GuilleAcoustic
    26 Nov 2010
    Reworked the external bigmutha rad. What do you think of it (do not pay too much attention to the frame around the rad, it's not finished) ?
  9. Cheapskate
    13 May 2007
    @Danitgeek - The details are lost without the lines turned on.:( The 120X2 in the top looks dinky.
    ...dinky:lol:
    @Guille - Not as clean as the original.(yet)
  10. GuilleAcoustic
    26 Nov 2010
    Here is my final entry : CU-932
    HAF a tonne of copper, HAF air cooled, HAF water cooled ... but not HAF cool. 100% cool :lol:
    - Fit a quad-opteron 12-cores and its quad-opteron 12-cores expansion board (96 cores crazyness)
    - 6x hot-swap HDD bay
    - 6x HDD activity LED (1 per drive)
    - Motorized HDD door
    - 2x 220mm intake fans
    - 3x 120mm exhaust fans (2x top fans, 1x back fan)
    - full copper top acting like a passive rad
    - massive surrounding passive rad (3m² of dissipating surface)
    - Quick disconnect connector to connect the rad to the case (easy maintenance)
    Custom waterblocks / passive air cooled :
    dual CPU block
    dual GPU block
    Hope you like it.
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    My entry didn't change since I posted it the first time back then -> http://forums.bit-tech.net/showpost.php?p=2709774&postcount=171
    Modding a case should allways keep the basic case recognizable imho. If you don't like a case to start with, then you either buy another one or make one from scratch.
    Nevertheless, some good concepts as allways in here.
  12. Gearheaddan
    Gearheaddan What's a Dremel?
    6 Jun 2011
    I'm not sure if i am able to enter this contest being I am new to this site but i made a design anyway if its not eligible to enter that's cool it was fun to do anyway.
    I call it HAF ROD
    I designed it after the front end of an old school hot rod and tried to keep it to something that would actually be able to be built in regards to cost and still somewhat resemble the original case.
    There are 2x 200mm fans behind the front grill, the air cleaner intakes on top are for the cpu radiator, and the hot air from the rad exits through the exhaust pipes.
    The power and reset buttons are located on the rear of the case along with the fan controller.
    I changed the top psu mount into an extra exhaust vent.
    On the inside the big box on the top houses the radiator and fans.The graphics card covers match the color of the outside of the case, the wire management holes are trimmed in aluminum, and the custom cpu water block is made to look like a finned valve cover with the tall style valve cover bolts to hold it on. i left the stock hard drive rack because it seemed to go well with the case .
    Hope you guys like it good luck to all who enter.:rock:
  13. j0rd
    j0rd FLOSS folder
    13 May 2011
    most definitely not your average 32 ford :)
    those HDD sleds would look great styled like an old halibrand quick change diff or some such.
    Sick design, love it :D
  14. GuilleAcoustic
    26 Nov 2010
    I agree with you and this is why I did the piece of wood (covering the top and front of the case) shaped as the original HAF-932 (large chamfers on the front edges and a platform on the top).
    I replaced the front 5.25" bay cover by a vented wood plate since I do not use them on any of my PC.
  15. confusis
    5 Jan 2006
    Couple hours to go folks! Late entries will not be accepted (well they will be, just messing with ya!) Hope you've all got your final pics up, will start a voting thread within the next few days :)
  16. eeced
    26 Mar 2007
    Hasn't 8am already come and gone? Not to sure about the timezone the forum is in.
  17. GuilleAcoustic
    26 Nov 2010
    maybe julian calendar .... :lol::lol:
  18. eeced
    26 Mar 2007
    I see... so who's this Julian and how can I contact him so I can get his calendar? :confused:
    @Gearheaddan : I like red, I must make a red case once I can get my hands on a decent one (case that is). Thx for the inspiration. :)
    PS. Joking about the julian calendar. :p
  19. Cheapskate
    13 May 2007
    Good stuff!:D
    We had a pretty light turnout this time. -Of course the open format comps bring in a lot of stuff people were already designing.
  20. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    Would show my entry, but since I only had time to put in 1-2 hours I'll pass :hehe:
