SketchUp MNPCTech Design Contest Volume 6 - Modify a Cooler Master HAF 932
Discussion in 'Modding' started by confusis, 16 May 2011.
  1. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    I suggest that we should hold up to the original intention, modify a CM HAF, not starting a scratch. Also by the word 'frame' i understand basic chasis - plain SECC frame completly stripped off w/o any plastic parts, fans, whatever, with the same dimensions. tho Confusis said we can cut it, im going the 'do not cut your HAF' way.
  2. Cheapskate
    13 May 2007
    Any sign that you were at least trying to use the haf model would help here...
    -80 fl oz of diet Coke and things like this happen.
  3. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Will review the deadline on the 10th :)
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Today's work, still a lot to do. What's new ?
    - Added a dual 200mm Rad on top
    - Made a custom "heat exchanger" on the back. It's made of a single block, which includes a 140mm rad in the center and 2 "channels" at the entry and at the exit. Those channels help to dissipate heat through the back fins.
    Hope you like the idea :lol:
  5. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looking really nice !! that motherboard is huge :D
  6. GuilleAcoustic
    26 Nov 2010
    Thanks mate :). This mobo is so huge that it almost fill the HAF by itself :lol:
  7. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    That's the Tyan Thunder n4250QE I think. C'mon, use the Tyan Thunder M4985-SI Expansion Board & HT-cards as well. You know you want to. :D
    Edit: Come to think of it - maybe you already did. Hard to tell from the pictures.
  8. Cheapskate
    13 May 2007
    That heat exchanger/radiator combo is delicious.
  9. Cheapskate
    13 May 2007
    The deadline approaches, and everyone got quiet.:worried:
  10. GuilleAcoustic
    26 Nov 2010
    Update incoming tonight .... I did fit the expansion board .... 8x opterons + 2x Radeon 6990 .... with everything watercooled (well, massive use of custom cooling hardware :lol:)
    Just need to add the hotswap HDD bay.
    Done, update incoming :lol:
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    I've finished my thingy two days after launch of the contest... waiting for the last day to post pictures :yawn:
  12. GuilleAcoustic
    26 Nov 2010
    can't wait to see it :rock: ...
  13. Dark~3nergy
    14 Jan 2007
    i haven't had the time to do much more then this :/
  14. eeced
    eeced My finger is in the fan
    26 Mar 2007
    Still working on mine. I'm not too experienced with sketchup so things are taking a bit more time to do than it would for others. I don't stand a chance against the epic monster hafenstein anyway. ;D
  15. k0rben
    22 Jul 2010
    this +1 :naughty:
  16. GuilleAcoustic
    26 Nov 2010
    Today's update :
    I'm near final design. Still have to refine the overall look, but I'm happy with the concept :D.
    Here are the pics (I know, it looks like a snail or a "@" :blush:)
    Outside :
    Inside :
    In blue, the radiators (passive and active) :
    Hardware and cooling bits :
    Air flow :
    I hope you like the idea. I still have to make the CPUs blocks.
    There won't be much tubing since I decided to use "channels" acting like passive heat-spreader.
    Edit : Close-up to the custom Radeon 6990 block (inspired by the enzotech GTX 295 block)
    j0rd likes this.
  17. j0rd
    j0rd FLOSS folder
    13 May 2011
    now that is immense...one sick design 4 sure +rep :)
  18. Cheapskate
    13 May 2007
    me like. me want.
  19. Gearheaddan
    Gearheaddan What's a Dremel?
    6 Jun 2011
    Wow nice designs just wanted to ask a question i came across this from a link on MNPC Tech. I was wondering if i would be able to make an entry being i just joined the site or do you guys have a rule about being here for so long or something before you can enter? I looked but didn't see anything about this in any of the rules.
  20. asura
    asura jack of all trades
    22 Apr 2009
    Aye, that's looking sweet!
    Had even less time than I was expecting to work on this, and really can't dedicate any more time to it, so this is what I've got to finish with.
