SketchUp MNPCTech Sketchup Case Design Competition 3
Discussion in 'Modding' started by confusis, 7 Sep 2009.
  1. razerz
    razerz What's a Dremel?
    2 Aug 2009
    Not crazy enough ehh? Let's see what you think about this one then :D
    Five compartments, all with quick release barbs at the back, to allow you to rearrange/carry it piece by piece. I just need somewhere to mount the PSU and harddrives.
    I have a vague idea of having the computer compartment filled with oil, and cool the chips both via water, that runs inside tubing not yet there. The water (and possible oil) will also recieve slight cooling from the heatsink at the back of their respective compartments.
    I have also taken your suggestion and modified it a bit. Somewhere under all those heatsinks over the motherboard, RAM and graphic cards, there are a waterblock. The idea is that the heat that the water don't pick up is evenly distributed in the oil/air around the heatsink.
    Good/clever/stupid/strange idea?
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Cool. It reminds me of a book shelf stereo. Wouldn't there be enough space for those components on the floor of your left and right radiator modules? The entire thing can be plumbed with dielectric oil instead of water.
  3. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    here is my "final" entry, in case I won't be able to finish it before the deadline. :)
    it's 35*35*38cm btw.
    I hope you like it :)
  4. stonedsurd
    11 Mar 2009
    Like it?
    freakin' LOVE it! :D
  5. Dark~3nergy
    14 Jan 2007
    hehe ^^ thanks
  6. jhanlon303
    7 Sep 2006
    @Dark
    Sweet!!!!!!!!!!!!!!!!!!!!!!
    I would have that on my desk and in plain sight.
    Don't know what all the sections are - but they fit right:rock:
    john
  7. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Just gorgeous dark pure unfaltering beauty :rock:
  8. Cheapskate
    13 May 2007
    @Razers - I'm with Bill. You need an '80s boom box handle on it.:D
    @Dark - Snazzy! Oil cooled Level 10. The floating compartment and round edges really set it off. If you are really building this, how do you access the tank?:eyebrow:
  9. Dark~3nergy
    14 Jan 2007
    the metal part around the tank can be removed, and then you can access the tank from above
  10. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    You guys are making it painful for me to read this thread... You see, I've had a few ideas bouncing around in my head for the past few days, and for once it wouldn't be SFF. It would make for an epic case, yet I've got absolutely no time to sketch it up.
  11. Editor22
    3 Jan 2009
    theres always time for some sketchup.. isn't there? :naughty:
  12. Cheapskate
    13 May 2007
    @Craig- Do it anyway!!!
  13. craigbru
    28 Feb 2008
    You guys are a seriously bad influence on me... I'll see what I can come with.
  14. Cheapskate
    13 May 2007
    Yay! I sent someone else down the wrong path!
    ...Don't take that out of context, please!
  15. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    ^^ and another one bites the dust
  16. Editor22
    3 Jan 2009
    Well I'm not sure its up to darks entry but here is my humble effort :)
    total size (L x W x D) = 400mm x 400mm x 350mm
    Fully watercooled thanks to the dual loop each containing a 2x120mm rad in push pull with triple gfx being cooled by a custom water block also put in a handy touchscreen so no monitor needed :)
  17. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    isit time already ??? i thought i still got some days ??
  18. razerz
    2 Aug 2009
    You still got a week and a half. Deadline isn't until November 1st. I love both of your designs Dark and Editor! Gonna have to get a bit more creative with mine.
  19. Cheapskate
    13 May 2007
    I'm hoping we get a ton of surprise entries again.
    @Editor - Quite nice. Still sane, but nice.:hehe:
  20. Colt 45 J
    Colt 45 J Aye
    9 Oct 2007
    A bit of a teaser to my entry I'm going to throw into the hat. This is just a bit, there is still a ways to go. Hopefully I can find the time to finish. It's modeled off of a jet turbine. I think it looks pretty cool so far, lemme know. (the video is kinda fast to save on space, but it seemed the easiest way to convey all the bits and pieces so far)
