SketchUp MNPCTech Sketchup Case Design Competition 3
Discussion in 'Modding' started by confusis, 7 Sep 2009.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    the mail with my final pics is out to confusis, now itll be up to youse to decide :)
  2. Colt 45 J
    Colt 45 J Aye
    9 Oct 2007
    I've gotten all of the brackets in, just have to add fasteners, figure out how cable routing works (never really used it before), and add a few more touches. Will post what I have soon.
  3. Colt 45 J
    Colt 45 J Aye
    9 Oct 2007
    [​IMG] Teaser :D That's the back cut, still has some aesthetic touches (like a cover panel) that need to be added, but that's the functional part. As well as the Fuel Gasket that is used as a power plug input. I have a feeling those rivets will be a pain...
  4. lenne0815
    4 Jul 2009
    nice colt, i feel it would have looked even better if u kept the outer shape of a real turbine and stood it up like one of these cheeky lava lamps !
  5. Colt 45 J
    Colt 45 J Aye
    9 Oct 2007
    @Lenne, I couldn't because it'd mess up the airflow. I have it so the front is an actual oversized fan (not just a lookalike turbine), which pushes air over and out through the back, the back has a small exhaust fan to help cool it down as well. This baby would be super hot without any cooling ;) Aluminum is a great heat conductor you know.
  6. Cheapskate
    13 May 2007
    I like the bulkhead mount for the power.
    For radial positioning, I work in pairs on the opposite ends of the object from each other. If you can group them, then it's just a matter of rotating to the next hole.
    -Sooooo, that sounded like gibberish again...
    Position two rivets.
    copy
    paste
    rotate
    repeat.
    -And you probably know this already.:D
  7. lenne0815
    4 Jul 2009
    nah, i meant just the outer shape, i know that u need the fans, something faintly similar to this:
    http://www.skysthelimitaviation.com/images/HE550703-IBERIA-747-200.jpg
    because a "tube" is just a tube doesnt matter how u look at it ;)
  8. confusis
    confusis Kiwi-modder
    5 Jan 2006
    i tried doing something like that for the last contest but even with a m-itx board inside it was HUUUUGE. damn wings lol. the wingspan to scale would have been as wide as my bed is long.. i was doing a dreamliner lol
  9. Colt 45 J
    Colt 45 J Aye
    9 Oct 2007
    @Confusis
    Ah I grew up around airplanes and jets, so it came natural to me as a design idea. as for it being a tube, it's a cylinder with features on the ends, and the sides have their own details added as well. Not quite just a simple tube. You would be amazed at the number of parts that went into just making that shape for an outside body without any of the features.... was quite difficult. Should have more pics soon, weekend means work time for me.
    @Cheapskate
    I'm hoping I can do a radial and linear patterns to get the rivets done in a timely fashion, but don't know how well it'll work. I was surprised to find Solidworks doesn't have built in blind rivet models. I may just open it up in Inventor and use that to put the fasteners in.
    And I still would like to know if any of you are able to convert Sketchup models to Inventor or Solidworks part/assembly files... I would love to put in my Zotac mini ITX board instead of a sub in block ;) (Portable and folding is my design intent, you guys should see some more stuff probably later tonight or tomorrow, definitely by the end of the weekend.)
  10. lenne0815
    4 Jul 2009
    confusis, did u get me emails ?
  11. confusis
    5 Jan 2006
    indeed. will post on 1 dec
  12. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I agree, very nice lenne0815
  13. lenne0815
    4 Jul 2009
    thx mate, its a bit slow here, isnt it ? i want to see mooooore !!
  14. Colt 45 J
    Colt 45 J Aye
    9 Oct 2007
    Arg busy weekend, didn't get much done. Had other projects to take care of... I'll try and give you a run for your money lenne but dunno how it'll turn out ;)
  15. Cheapskate
    13 May 2007
    I'm out most of the time fixing my sister's house. I'm not getting anything done.:(
  16. confusis
    5 Jan 2006
    hmmmm i havent even restarted! arg!
  17. Cheapskate
    13 May 2007
    Getting quiet in here... I hope it's just the calm before the storm.
  18. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    moar pics needed! :D
    Here's what i'm working on at the moment. The little explanation in my project log:
    The "wave" on te left sidepanel is a direct copy of my gracious' sponsors logo: www.Highflow.nl .
    Also, the whole case is mathematically perfect. Dimensions: 256 x 289 x 361 mm.
    Yep, indeed that's 162 x 172 x 192. :geek:
  19. Cheapskate
    13 May 2007
    Thank you.:D
    I think I zoned out and watched that for too long, too.
    Have you found pcie extenders long enough for this?
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking good dude and I agree with cheaps, stop motion is hypnotic!
