Mobile Athlon
Discussion in 'Hardware' started by ApAcHe, 2 Sep 2004.
  1. ApAcHe
    ApAcHe What's a Dremel?
    2 Sep 2004
    Which should i buy out of the athlon mobile 2500+ and 2600+
    which would give me the best OC
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    NF7-s v2.0.. make sure its this revsion as well, as the newer boards have no mulit adjustment....
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Errm, I think he was asking which chip. :D
    Without knowing which stepping each chip is its impossible to say, but even then the difference will be minimal.
    TBH go for the cheaper of the two, as they will deliver a very similar result.
  4. Highland3r
    25 Jul 2003
    dammit ignore me then.... /me blames vodka...
  5. Spiral Architect
    Spiral Architect Cooked on Phonics
    4 Sep 2003
    I don't believe there is much difference.
  6. Go4t
    Go4t i
    13 Dec 2003
    i think bigz said in the other thread that you might get more out of the 2600
  7. Firehed
    15 Feb 2004
    Actually the new boards with crap overclocking are completely different. NF7-S is the good one, NF7-S2G and NF7-S2 are the bad ones.
    But yeah, you're more likely to get a bit higher witha 2600+M.. I think on average they seem to top out around 100MHz higher.
  8. TMM
    TMM Modder
    12 Jan 2004
    there has been some very good 2600+'s lately, but that not to say there isn't any 2500+'s that can do better
