Notebooks Mobile broadband PAYG sim?
Discussion in 'Hardware' started by veryevil, 1 Nov 2008.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    hey I'm looking at getting mobile internet most probably from three however I want to use an internal card and was wondering if I could just get a three PAYG Sim or if it needed to be a special sim to use the pay as you go mobile broadband
    Thanks
  2. sandys
    sandys Multimodder
    26 Mar 2006
    no its any three sim you'll need a 3g phone to activate it though probbably.
  3. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey thanks but that doesn't really clear it up.
    you think any sim will do but it will need activating?
  4. sandys
    sandys Multimodder
    26 Mar 2006
    The sim card is not activated when you buy it, normally you make one phonecall with it, they tell you give it 5 mins and its activated, the process is automated though so it might be that a data call would activate it but I've never tried.
    Three will offer next to no support when you use there sim in a non 3 branded piece of kit if they don't sell an equivalent, but I've had no problems activating and using mine in Windows CE phones.
  5. darklord of chaos
    darklord of chaos What's a Dremel?
    23 Jan 2007
    ok this I know about as I am trying to get rid of my 3 mobile broadband, you need to use their own usb dongle second it is not worth it as surfing the web on my phone ( on 3g) is faster i could count on one hand the number of times I have connected via HSPDA, unless you need it for work or something even then look elsewhere maybe vodaphone.
    I would not recomend it. I would rather have root canal without painkillers
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Having come from vodafone I can't praise 3s speed and coverage enough, guess it depends on where you live.
    Also I don't have any 3 hardware at all and have no trouble.
