News Mobile devices waterproofed by MilTech
Discussion in 'Article Discussion' started by CardJoe, 1 Jan 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    Curious too say the least. I wonder how unbeliveably ridiculously expensive it is though.
  3. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Mobile phones? Pah!
    I'd prefer to get my motherboard and graphics card Ion-Masked, then never worry about a leaking water-cooling loop ever again. :p
  4. samkiller42
    25 Apr 2006
    I bet, hopefully wont be OTT
    Why, use the correct water and it doesn't matter:thumb:
    All this Ion-Masking sounds fun, may be able to get a water proof coat that doesn't let water in:wallbash:
    Sam
  5. sam.g.taylor
    sam.g.taylor Apparently I'm Greg Kinnear
    15 Aug 2006
    Does anyone have an idea as to what kind of cost this would incur? I understand that as it's used more frequently cost would come down, but as with any next-gen technology there are always those first few people who can afford the high price...
    I wish I was one of them.
  6. Cptn-Inafinus
    3 Mar 2007
    Actually, this could be very intresting. If you could do this too all the componentry in your computer, you could submerge it in water. Alot like the oil cooled PC's you see. Running costs would be alot lower than oil as well.
    Intresting...
  7. Zurechial
    Zurechial Elitist
    21 Mar 2007
    As soon as water touches your copper or aluminium water-blocks and rads, it absorbs particles from the metal surfaces and becomes conductive, no matter how purely distilled or deionised it was originally, and specialised coolants marketed as being non-conductive have been repeatedly proven to be conductive enough to cause damage to components if leaked. :p
  8. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    in fact deionized water can at times be more corrosive than normal water among other things the pH of deionized water is quite a bit lower than tap water.
    With regard to the submerged computer idea (which was the first thought that popped into my head) we would naturally like to know whether this coating changes the heat conducting properties of the material it covers, and whether the coating is affected by temperature fluxes.
  9. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    also from the sounds of it, if it's changing the surface structure at a molecular level to repel water, I believe the heat transfer would be lower as well as water isn't interacting as closely with chip surface as before.
    very intersting tech, I wonder on a more detailed level how it works. you think in 5 years will all cellphones come pre waterproofed?
  10. Zurechial
    Zurechial Elitist
    21 Mar 2007
    I'd imagine it'd work like an unmoving flow boundary layer of water and insulate the components slightly.
    My knowledge of the topic is limited but pdf27 would probably know. :p
  11. Seraphim Works
    Seraphim Works What's a Dremel?
    18 Apr 2007
    If not too expensive, this could be great for things such as waterproof hearing aids, etc. Having to go without when swimming in the sea with the girlfriend, etc, could be a thing of the past.
  12. HellRazor
    HellRazor What's a Dremel?
    26 Jun 2005
    quote - "Fancy making the trip just to ensure your iPod will keep working after a dip in the sea"
    I doubt even doing this to the Ipod would make them any better.... bloody thing would most likely break during the treatment!
  13. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    Having just doused my laptop with a misdirected shower hose I can definitely see the need for this. Bit late in my case, but hey, my next laptop might work in the bath, not just next to it. (BTW I was keeping an eye on an ebay auction, not pr0n... for those who were wondering).
  14. Jaguar_Infinity
    Jaguar_Infinity Just some guy
    8 Oct 2003
    This would be great for me. Im a watersports instructor and i go off on remote wilderness expeditions and to be able to ensure any tech stuff i take stays in working order from water would be invaluble. Can you imagine how serious having your satalite phone not working due to water damage after you've had an accident (like breaking your leg or hip) when you need to call a float plane in to pick you up and get you to hospital? let alone not having to worry about a camera or normal phone or anything else while your on a days trip down the river even here at home (i've actuall killed off 2 and nearly killed of a third electroic device due to water damage)
    I know alot of people will comment that you can get aquapak cases etc for your devices but after use the seams break (and you may not notice for a while) or you dont seal it properly (again you think you have) and then they get a swim with you down a white water rapid where theyre bouncing around (even smashing against rocks) it definiately tests your equipment and IMO those cases people talk about can't always be relied apon.
    Stuart
Tags: Add Tags
