Motherboards Mobo can't see PCIe Sound cards
Discussion in 'Tech Support' started by Aragon Speed, 9 May 2009.
  1. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    I recently decided to upgrade my on-board sound to a fully fledged sound card. Well that was a mistake... :D
    Motherboard: Gigabyte GA-EP35-DS4
    Bios version: F5
    I bought an Asus Xonar DX and happily fitted it. Only windows didn't see it, and after a little exploration I noticed that the bios wasn't seeing the card at all, not even an "unknown" card listed in a slot.
    Not to be daunted, I assumed the card was FUBAR, but before I went off to start screaming at ASUS for a replacement, I thought I had better make sure it was the card.
    So I went and forked out more cash on a Creative X-Fi Titanium.
    Still no joy. :sigh:
    Help? :waah:
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    Have you tried disabling any onboard sound adapter on the motherboard in the bios?
  3. Aragon Speed
    12 Jan 2009
    Yes, I disabled it before I installed the new card(s).
    Info I missed in the OP.:eyebrow:
    OS: Win XP 64 SP2.
  4. capnPedro
    11 Apr 2007
    Did driver installation result in an error?
  5. Aragon Speed
    12 Jan 2009
    Yes, it says something along the lines of it not being able to find the card, and then aborts the driver install.
  6. Fod
    26 Aug 2004
    stupid question here, but are you sure the card is pci-express, and plugged into a pci-express slot?
  7. Aragon Speed
    12 Jan 2009
    :D Yes. :D
    There are no stupid questions, only stupid answers. ;)
  8. bullseye
    bullseye Who dares wins
    28 Apr 2009
    Not sure if you are using two gpu's or the second pci-e slot but found this in the mobo manual.
    (Note 2) When the second PCI Express x16 slot (PCIE_16_2) is in use, the three PCI Express x1 slots
    become unavailable.
