Motherboards Mobo for a i7-3770s
Discussion in 'Hardware' started by Dazza007, 21 May 2012.
  1. Dazza007
    Dazza007 New Member
    9 May 2009
    I'm thinking of upgrading my HTPC (E6750, Gigabyte P35C) and im into the i7-3770s chip, can anyone tell me what the 's' stands for because there is also a 'k' which I assume is for OCing. would it be better to go with an intel mobo: Intel® Desktop Board DH77KC or a third party branded mobo and if so can anyone tell me whats the best chipset/board combo, I'm not really into OCing, I just want a quiet PC with low power draw but good performance. this CPU has the same TDP as my E6750 chip but with an extra 2 cores :)
    Regards
    Darren
  2. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    No point getting the S, its just a power saving, worst performing version of the standard chip. The K version is indeed for overclocking but it also has the best resell value out of all the chips. For the mobo, a 3rd party one will indeed be the best choice, but it depends on your budget.
  3. Dazza007
    Dazza007 New Member
    9 May 2009
    its actually the power saving im after, my pc is on 24/7 so power saving is crucial. Saying that I agree with your point on the resale value as my E6750 is going for about £30 on ebay but a QXXX is in the hundreds. thing is I wouldnt buy a 2nd hand QXXX as you do not know if the previous owner OC'd it badly. Any recommendations on a mobo for either a 3770s or 3770k then?
  4. mikeyman198
    12 May 2011
    Still the S version will hardly make any difference compared to the K version with power saving, and if you really want, you can make a K version into an S version by underclocking it. And again, I would need a budget for the mobo to recommend you one.
  5. Dazza007
    Dazza007 New Member
    9 May 2009
    my budget is whatever I need to spend, tbh, I've got my eye on the ASRock Fatal1ty from scan for £185, rule of thumb being you should spend the same amount of money on the mobo as the cpu, but i think £230 on a mobo is too much (for me anyway). are there any better mobos due to arrive on the market soon, should I wait?
    the k version uses 12w extra over the s version which is the same as an electric light bulb.
  6. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Personally there are a few points to go for the K over the S:
    1) It will OC if you ever need to turn said HTPC into a gaming rig/ever feel the need.
    2) It will sell a lot better and hold more value further down the line
    3) You could underclock it to the speeds and potentially lower volts than the S version if required.
    4) It will be pretty close on power draw either way.
    Just a few points there.
  7. Dazza007
    Dazza007 New Member
    9 May 2009
    good point, the k is £28 more than the s and i know i'll get more than that back if i sell it so im gonna get the k, now the motherboard?
    I bought the ASRock fatal1ty pro.
    cant foolin wait.
