Modding mobo heat pipes
Discussion in 'Modding' started by disturbed13, 6 Feb 2010.
  1. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    okay i have this mobo
    and i was wondering if there is anything besides air inside those heat pipes?
    are they solid?
    or hollow?
    i have some conserns about my plans and the heat generated by them
    here are the specs from newegg.com :D
    thanks for the help
  2. Attila
    Attila still thinking....
    22 Feb 2008
    They are hollow and there is some gas inside.
  3. capnPedro
    11 Apr 2007
    Schrödinger's heatpipe. There's also some liquid inside.
    mvagusta likes this.
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    I feel your effort of humour has eluded many, I also suspect you wont find a cat in them. lol!
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    There's also some non-quantum wick inside.
  6. disturbed13
    28 Nov 2008
    ............................ what?
    im as lost as i was when i started this thread
    what kind of gas?
    would it be a bad thing to cut them?
    is the liquid a condensed form of the gas?
    or what
    i need more details then that.
    thanks for the replys tho
  7. FrooP
    FrooP can I eat this?
    24 Oct 2007
    there is, im not kidding, water in them, the pipe is under a vacuum so the water is in gas form at normal temperatures, you "could" propably cut them open and mod them to work as water coolers, havent tried yet though
  8. Horizon
    Horizon Dremel Worthy
    30 May 2008
    don't remember where i saw it I think it was here or xtremesystems, but inside is liquid and what appears to be rystal granules that line the wall of the heat pipe and act as the thermal wick.
  9. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Heat pipes contain a very small amount of liquid in them. Unlike what most people think, the heat pipes do not contain any air. The liquid is put inside the tube under a vacuum. To allow for the vapor to return from point A to Point B after heat is applied the heat pipe uses a wick structure (either mesh, slinters, foam, extrusions, etc) to return the evaporated liquid. Most PC heat pipes use de-ionized water or some similar chemical. If you really want to know more about heat pipes I recommend you read this book: http://www.amazon.com/Heat-Pipes-Fifth-Theory-Applications/dp/0750667540
    If you want to get custom heat pipes you can buy them here: http://www.enertron-inc.com/heatpipe.asp
    And yes, I have bought heat pipes from them for an ISEF competition project in my Sophomore year.
    edit:
    Been there done that (was my ISEF project coincidentally lol), and it works quite well depending on how you design it. However, you can't cut them and use it. Won't work as you can't get a vacuum again.
    edit2:
    Sorry to hijack the thread, but any one here know where to buy plate like heat pipes like those used on laptops?
  10. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Some heatpipes do have air in, there will never be a vacuum inside though as some or all of the operating fluid will be in it's vapour phase. The pressure is reduced so that the water boils at around the operating temperature of the components to be cooled, the water vapour then travels through the heat pipe to the cool end (or coolest point in a multidrop system) where in recondenses. The energy absorbed from the components in boiling the water is transferred to the fins at the cool point when the water recondenses. The water then travels back to the hot point and the cycle continues. The wick is incorporated to move the water back to the hot point even if it's above the cold point. For heat pipes that are operating at extreme temperatures the water may be replaced with a different liquid.
    The flat heatpipes used in laptops are called planar heatpipes, you might find a manufacturer if you google that term.
    Moriquendi
  11. disturbed13
    28 Nov 2008
    okay well the reason why i ask is because i have some heat pipes that are covering the MOFSETs on my mobo
    and they are tied into the North Bridge and South Bridge block.
    i dont want them to be
    i want to remove the NB & SB from the loop
    and take care of them seperately
    the MOFSETs will have small fans blowing on them from start-up to shut-down
    so im not worried bout that at all
    what i am worried about is cutting the pipes and ruining the cooling power of them
    any suggestions?
  12. Shadow703793
    5 May 2009
    True that. But it is close to a vacuum. And I will look in to the planar heat pipes.
  13. Shadow703793
    5 May 2009
    Custom built water cooling on the NB and SB and some plain old MOSFET sinks should work.
  14. capnPedro
    11 Apr 2007
    Don't cut them, you WILL ruin their heat transferring properties.
    It won't be the first time.
  15. disturbed13
    28 Nov 2008
    i have a link at the top of the page of my mobo
    so you guys think that i shouldnt cut the heat pipes to use the current heatsinks that are supplied?
  16. Shadow703793
    5 May 2009
  17. talladega
    talladega I'm Squidward
    18 Aug 2007
    they are made using a time machine. you need a hardon collider to take them apart.
  18. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    :eyebrow:
  19. disturbed13
    28 Nov 2008
    ive been thinking about seperating the MOFSETs from the NB & SB block
    and as you can see they are kinda connected with heat pipes
  20. Javerh
    5 Sep 2006
    A normal-sized heatpipe using water as the medium has an internal pressure of 0.1-0.15 bar. That kind of vacuum can be easily made at home with a simple pump or a syringe. The hard part is sealing the end of the pipe.
