Mobo recomendations?
Discussion in 'Hardware' started by unicorn13, 2 Oct 2007.
  1. unicorn13
    unicorn13 What's a Dremel?
    26 Feb 2007
    Hi all,
    I am looking for a new mobo I would prefer Abit, Asus or Gigabyte, socket 775, Intel core duo, at least 1 PATA coonector etc.
    Only thing is it needs to be aroung to £100 inc vat range, the only game I like and have are, Doom 3, Quake 4 and Halo 1, and office work :(
    So it needs to be an all rounder.
    Recomandations welcome, need to update as my AI7 is getting a bit old :)
    regards
    Andy
  2. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    do you need RAID, firewire, serial ports etc.?
    1 of the abit or Gigabyte P35 chipset mobos should do you.
  3. shadow12
    shadow12 I lie
    30 Sep 2007
    Gigabyte P35C-DS3R Supports DDR2/DDR3 on scan its about 73 pounds FSB up to 1333 and support for the 45nm processors comming out.
    Other options are
    Gigabyte GA-P35C-DS3 ICH9 instead of ICH9R for 71 pounds
    Asus P5KC for about 80 pounds
    Now the difference between the DS3R and DS3 is minimal as well as the price but they have slightly different backpanels so its up to prefs. The Asus looks cool but again its all up to your specs. I doubt you would see much difference between the motherboards performance wise.
    Hope this helps!
  4. wyx087
    15 Aug 2007
    how about the Abit iP35 -E??
    my Pro is superb
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Second on the Gigabyte P35C-DS3R, Abit iP35 -E looks interesting but i havent had a fiddle with one yet.
  6. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Abit IP35-E seconded here. It is an amazing overclocker, and one of the cheapest P35 boards on the market today. Unless you need more features than that board can offer, go for it, and if you need eSATA, just buy a PCI slot adaptor, they only cost £5.
  7. Guest-16
    Guest-16 Guest
    Do you need C for CrossFire? The non-C version has more useful ports afaik.
  8. shadow12
    shadow12 I lie
    30 Sep 2007
    For the Gigabyte mobos C is not for crossfire even ones without C in the name have crossfire. As far as I can tell if the name has a C in it it means it supports DDR2 and DDR3 RAM.
  9. Burnout21
    9 Sep 2005
    spot on with that, the 'C' is DDR3 support aswell as DDR2
  10. Guest-16
    Guest-16 Guest
    Ah, yea I just remembered. There's so many DS3s it's confusing.
    Basically - don't ever bother with a combo board - they make the BIOS a compromise between DDR2 and DDR3 so it's neither super compatible or super performing like a single type of board.
  11. Burnout21
    9 Sep 2005
    i disagree with you there mate, the gigabyte is faster than sh*t off a chrome plated shovel.
    yes in the past such combo boards that mixed AGP and PCI-E, cough 'Asrock' were slow in performance but made up in there value.
  12. Raiderfan001
    Raiderfan001 I know what a Dremel is.....
    2 Oct 2007
    Between Abit and Gigabyte I'd choose the Gigabyte. Asus is very good as well and would get it before buying another Abit.
  13. unicorn13
    26 Feb 2007
    Hi All,
    Have been looking at these what do you think:- (No particular Order)
    1. Gigabyte GA P35-DS3P, Gigabyte GA P35-DS4 and Gigabyte GA-P35-DS3L
    2. MSI P35 Neo-F
    3. Asus P5KC
    4. Abit IP-35
    Thanks for recomendations/help so far
    Andy
  14. BUFF
    25 Mar 2005
    DS3P seems to be the sweet spot atm for giving you features that you may want without the unnecessary (albeit they may be nice touches) fripperies. DS4 is same board with different cooling.
    abit IP35 wouldn't be far behind.
    As already mentioned combo boards (e.g. P5KC) don't tend to overclock as well as boards dedicated to 1 type of RAM - I know of a well known overclocker who switched from a P35C-DS3R to an IP35 & much prefers the abit.
  15. Elio
    Elio What's a Dremel?
    4 Oct 2007
    why not go for the asus p5k delux more features ,good overclocking features and the price isnt too high...
  16. wyx087
    15 Aug 2007
    don't you think it's got way too much features?
    my vote for Abit iP35.
  17. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    One more for IP35. I can tell you right now, it's the best $100USD board around. Period.
  18. Elio
    4 Oct 2007
    the p5kD doesnt have way too much features and the price doesnt differ much than the ip35...
    well in the end it depends what you need it for...
    both of them are very good cards...
  19. ivanrlynn
    ivanrlynn Whats a Mod?
    15 Jul 2007
    I agree you can't beat abit stuff, the E is just the same board without the nice colour and trimmings
  20. unicorn13
    26 Feb 2007
    Hi all this is what i am thinking of:-
    Just gotta post a few more times to get Scan discount :D (bought a good few things from them over the years)
    Hows this sound, only thin I am not sure about is length of cables for mobo as the case I have is the Antec 900 V1.1.
    Shopping List
    Abit IP-35, iP35 Express, S 775, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, ATX
    Intel Core 2 Duo E6600, Socket 775, 2.4 GHz, 1066MHz FSB, Conroe Core, 4MB Cache, Retail
    2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 4-4-4-12
    256MB BFG Technology 7300GT PCI-E (x16), Overclocked, GPU 375 MHz, 8Pipes D-Sub/DVI-I/HDTV
    700W EZCool Infinity pPFC Low Noise ATX v2.2 Dual +12v Rails EPS12v 2.1 SATA/PCIE Ready 12cm Fan
    500 Gb Samsung HD501LJ Spinpoint T, SATA300, 7200 rpm, 16MB Cache, 8.9 ms, NCQ
    £445 Delivered
    Whad ya think?
