Planning Mobo screw Layouts
Discussion in 'Modding' started by sixfootsideburns, 23 Jul 2010.
  1. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    Anyone know of a location for a good schematic that shows mobo screw layouts for the different form factors?
    thanks a bunch!
    sideburns
  2. ARM
    ARM Minimodder
    15 Sep 2004
  3. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    I have one in Google sketchup if you want it? Or I could send you a to scale ready to print out version of it?
  4. bushi
    bushi What's a Dremel?
    8 Jul 2010
    Could you post them up here please?
    I'd put it to good use. :D
  5. riekmaharg2
    22 Feb 2009
    Here you go:
    Pic sample:
    Click Here to download
    You will need to edit it abit, as its for my scratch build and the PSU is under the MB tray which isnt the usual place.
  6. bushi
    8 Jul 2010
    Ah sweet thanks mate.
