Mobo Selection
Discussion in 'Hardware' started by DeathJester, 13 Jan 2002.
  1. DeathJester
    DeathJester What's a Dremel?
    6 Jan 2002
    Alrighty, my Mobo is pronounced legaly dead ;) I wanna KT266A, stable overclocking, if RAID can be used without RAID'ing the drives I wouldn't mind RAID, I don't want onboard sound or modem, and I really don't care about the price. Don't give me your marked out opinions. I want the honest truth based on benchmarks and stats of the boards.
  2. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Well then, that would seem to come down to the EpoX 8KHA+ or the Abit KR7A-RAID then. My choice would be the Abit.
  3. Will
    Will Beware the judderman...
    16 Jun 2001
    I say Abit as well really
  4. DeathJester
    6 Jan 2002
    What about the MSI Pro2-RU? Also I heard BAD things about the Epox. Also I heard the Abits RAID is horrible!
  5. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    The abit's RAID controller is interesting...ATA133 capable, although for some reason it has problems with my dad's Barracuda IVs, and only runs them at ATA66. I believe this will be fixed with a BIOS update.
    I thought the MSI had things like sound on board?
  6. DeathJester
    6 Jan 2002
    I can deal with the onboard sound I guess, but no modem or LAN
  7. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Hmmm
    The Abit has 6 PCI, while the MSI trades one PCI for the USELESS CNR slot. You've got on-board sound on the MSI also. Both are compatible with large HSFs, such as the Alpha PAL8045. The Abit has 4 DIMM slots, compared to the 3 of the MSI. The MSI has USB 2, which the Abit does not. The MSI only has 6 mounting holes, allowing the board to flex/break when installing IDE/Memory. The Abit has 9.
    Both Anandtech and Tom's Hardware didn't think a great deal of the MSI, both placing the EpoX higher in their ratings.
  8. DeathJester
    6 Jan 2002
    I don't mind the 1 loss of a pci slot, but 4 holes? Hmmm, I think I'm going with that Abit.
  9. Popeye666ca
    Popeye666ca What's a Dremel?
    13 Jan 2002
    Whats wrong with the Gigabyte GA 7ZXR. Its got on board Raid.
    I need some ideas myself please. Just got a Intel N440BX server board twin cpu. It can run PIII 600's. If I got a slocket, anyone know what the fast thing that I could use please. Or does anyone know how to work it out.:D :cool:
    Thanx 4 NE help
  10. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Are you sure that board is Slot 1? Most dual slot boards (if not all) were slot 2. Check.
  11. Popeye666ca
    13 Jan 2002
    Nah.
    Slot 1 it is.
    Intel site says slot 1 to socket 370 are not supported but that doesn't mean I cant use them right.:rofl: :rofl:
  12. sco0by
    sco0by Mmm pie.
    12 Dec 2001
  13. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Yeah, get the Soyo K7V Dragon+. It's a fantastic, fantastic board. It simply has everything from excellent overclocking to good sound and raid. This has got to be the board to get and is worth every penny. www.chillblast.co.uk stock it at around £150:cool: :D
  14. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    hmmm....just to be aquard get the ausus a7v266-e, which according to most sites is the most stable, overclockable yet fastest mobo, but you do have to put the extra money down for it.....which u said u didnt mind.... http://www.hardocp.com do a review of it....
  15. Tim S
    Tim S OG
    8 Nov 2001
    If I was making the choice now, it would be a tough one between the Epox and the ABit KR7A.... I like the features and speed of the Epox, but there is the downside of the motherboard sucking out of the 5V rail :(
    Although I have a large psu, I still don't think it would handle the the board all that well :mad:
    However going on to the ABit, first impressions are, very well thought out layout, nothing is stupidly situated. The features look awesome, and I have an ABit at the moment, which is stable, and a good overclocker (my present CPU is crap, hence the low overclock) Ive had a duron 800 at 137FSB (7.5 x 137 1.03GHz) running the RAM with the most agressive settings... mmmmmmmm very nice :D also a TBird 1000 (200FSB) at 1240 (124 x 10)
    Hope this aids your choice :)
    BiGGiE
  16. Fatboy
    Fatboy Bored
    8 Oct 2001
    I would go for the KR7 myself.
    Tis' very good and iv had no problems with it .. so far.:rofl:
  17. DeathJester
    6 Jan 2002
    Blah, asus is the devil. They OC their boards.
    I dunno about the Abit, I heard the IDE Controller is RANCID. Is this true?
  18. BannedMojo
    BannedMojo Banned
    14 Jan 2002
    Onboard Components
    Just a note: If you are into overclocking - and plan on hitting high FSB speeds (150+), onboard components (sound, video, lan etc) are a risk because they may 'crap out' at high FSB speeds - making the whole motherboard useless.
    Good luck finding what you need - I also recommend Abit motherboards m8s have had good overclocks with them...
    Popeye: Slockets are generally annoying - If you want to stick great big fans on them (especially on twin CPU mobos) it can be quite a mission, they seem to generate more heat as well), I've only ever installed one of them on a colleagues (not a m8 so what else could I call him) Pc, and i didn't enjoy it one itty bitty bit. Good luck anyways.
  19. DeathJester
    6 Jan 2002
    Don't worry, the componemts on my pc are fine. I just wanna know bout that damn RAID.
  20. batsman
    batsman the quiet one
    14 Nov 2001
    you know it makes sence
    the ABIT deffinatly, that the next mobo i'm getting got an KG7 RAID at the mo and its v good.
    But the KR7 adds ATA 133.
    Got 9/10 from via so it must be good.
