[MOD] - Apple - PC - by zzubbione
Discussion in 'Project Logs' started by Zzubbione, 1 Aug 2005.
  1. Zzubbione
    Zzubbione What's a Dremel?
    31 Jul 2005
    Hello all.
    i'm a french computer modder.... well, sorry for my english ;)
    i am a long time reader of this forum, so, I finally decide to post here some pictures of my little MOD....
    it is right a small MOD without claim, made only by myself and for myself!! ....
    the comments, critical, easy ways, all, are naturally welcomes!
    first, here is my config:
    athlon 64 3400+,
    K8N AI series,
    2X 512 mo pc3200 twinmos,
    Leadtek 6800 GT TDH 256 mo
    hdd maxtor 80 go 8mo de cache,
    graveur lite on 42x,
    dvdrom lite on 16x,
    hauppauge wintv pci nicam,
    WB alphacool Nexxxos XP Nickel V2, CSP-750, BIP, and NoiseBlocker tank,
    Viewsonic G220f 22’’ ,
    External disk usb2 maxtor 80 Go 2mo de cache,
    scanner canon Lide 20,
    Printer canon IP1500,
    Mouse Trust 350 sx wireless optical,
    Keyboard trust silverline,
    kit 4.1 crambridge soundworks,
    video tape recorder LG (?!),
    thrustmaster force feedback racing wheel,
    pad thrustmaster dual analog2,
    modem router ADSL netgear DG834,
    router wifi Linksys WRT54G
    et E-Star box modded « apple-pc »
    (for those which would like to see more, kind all the modifications since the beginning, is necessary to go there -- > my MOD on SOJ... IN FRENCH!!)
    now, many pictures in the order.... erf, I hope.... good looking!.... and do not forget the coms....
    second or third version of MOD, I don't remenber.... -->
    and now, after many stages....-->
    [​IMG] [​IMG]
    CLICK ON THE IMAGES TO INCREASE SIZE... /!\ 1152*870
    [​IMG] [​IMG]
    and then modification of the back of the case.... To accomodate a 12cm fan...... -->
    [​IMG] [​IMG]
    and a night picture!…. so niiiiice!!! J
    after this version, it had other changes.... Much in fact.....
    first, the power supply (this is the originalversion, with metal sleeving... but for some reason, it not stay like this.):
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    and the front!!!!!!
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  2. Zzubbione
    31 Jul 2005
    next parts!
    [​IMG] [​IMG]
    the L.I.S…. first version of integration….
    but I did not like the apparent screws.... Then..... I manufactured, or rather "moulded", of the parts specifically made for the LIS!!!
    I used a second mask-bay, identical to the one used for the LIS...
    let's go, time to the pictures!.... for understanding, it is very easierwith pics....
    the LIS, with the "parts" home-made with bondo.... and the blue pane which f***ing me largely because it don't remained convex! after a small treatment the thermal decapor, it was shown much more flexible!!!:
    the bondo job and sandpapered frontage........ it is better without the holes and the screws!!!
    detail of a home-made parts!!!
    niiiice !!….
    then, i made that….. erf…. :/ :
    which became that:
    who help me to made that:
    the lighting system of this tiny apple:
    and then, many other home-made job:
    this parts will not remain like that thereafter.....
  3. Zzubbione
    31 Jul 2005
    one again!
    the original PSU became really powerless for the system, I changed it for a thermaltake butterfly 480 watts
    so, some modding on it:
    normally it looks like that, at the origin without modifications.... [​IMG]
    pics !:
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    The parts of the watercooling systems:
    the BlackIce Pro mounted on the back of the case….
    and here is: (left to right) WaterBlock Nexxxos XP bold Nickel V2, the tank Noise Isolator, the pump CSP-750 , 3 meter of pipe “LeGris”, and the UV liquid with anti corrosion.
    On top, the kit double Cold cathode UV 10 cm.
    and the final mounting, and pictures of the working system.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  4. Zzubbione
    31 Jul 2005
    to be finished.....
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    that’s all, folks!!!!….. [​IMG]
  5. Nexxo
    23 Oct 2001
    Bienvenue sur les Forums Bit-Tech, Zzubbione. :clap: Ne te fais pas du souci: ton Anglais est meilleur que notre Francais. ;)
  6. -Erik-
    -Erik- Guest
    Looks really nice, I like the display you got there .. looks really good!
  7. Zzubbione
    31 Jul 2005
    thanks. really.
    --->Nexxo: :clap: well... you're french looks nice.... maybe..., no, Surely better than my english! (thanks to google translator! :D )
  8. Firefox90
    Firefox90 What's a Dremel?
    14 Jul 2005
    Looks great man! BTW, good luck with that PSU. It was a POS for me and my 6800GT and AMD 64 3200+
  9. RegularChaos
    RegularChaos What's a Dremel?
    28 Jun 2004
    great mod!! im liking the apple love u got. a quick question, how did u frost the plexi? or is it frosted plexi? it looks great :rock:
  10. horgboy
    horgboy haisup
    25 Mar 2005
    looks really good cant wait to see whats going to happen next
  11. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    Looking really good! The radiator and back fan should be white tho :/
  12. B.Psycho8
    B.Psycho8 What's a Dremel?
    8 Aug 2004
    Wow that is so smooth simple and nice! Can't wait to see more :)
  13. white modder
    white modder What's a Dremel?
    19 Sep 2003
    nice man, very nice
  14. J-Nonymous
    J-Nonymous What's a Dremel?
    16 Jun 2005
    wad did u use for the sleeving? seems like metal tubing used for bath room hose... wont it short circuit the parts? seems dangerous to use thou
  15. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    i really like, there's a lot of attention to little details. that's why i like it so much. too bad you're not proud enough of your AMD64 3400+, i have 2 of them, a NewCastle and a Clawhammer. i really like your LIS VFD as well. i have an LIS2 BlueEye LCD, wish i had the extra cash to get the VFD, it's sooo much nicer. but you have another LCD on there. what kind is that?
  16. deiol
    deiol What's a Dremel?
    14 Jun 2001
    I LOVE Apple mods... hehe.
  17. tetleyex
    tetleyex What's a Dremel?
    29 Mar 2005
    Sorry... this is so bad....
    Whats wrong with english computers?
    Anyway... I like that funky apple lit up drive bay, Did you use a dremmel, or tiny files?
  18. Zzubbione
    31 Jul 2005
    well well well..... :blush:
    many questions and congrats!!!! great thanks to all of you!! :rock: :rock:
    so... time to answer.
    --->firefox90: the butterfly 480w is a good PSU. good voltage and they are really stable on full charge. (i buy this second hand one for only 60€.... so i modded it the same day than the postman give ite to me!!! lol)
    --->RegularChaos: i sanded the plexi with P400, P600 and P1000 wet sand-paper. but you must sand gently and smoothly in straigth line. mot in circle.
    --->horgboy: well.... i feel this the last stages of this mod... i hope... because... i have ordered this case... in november 2000...... and i begining the mod in january 2001... 5 final version at this time.... lol :D
    --->Jokkocze: ihave thinkinh about that... but, it is not planned for now. maybe in th e near future :hip:
    --->B.Psycho8, white modder, deiol: really thanks!
    --->J-Nonymous: well done. indeed, it's metal tubing used for bath hose. it's not very dangerous. simply, it should be paid attention that it don't have there a contact with the mobo or other electrical parts. ;)
    --->kaotic504: yes! i'm proud of my AMD64 3400+ (newcastle for the mine!).... why not??? its a powerfull processor! but.......but, it heats much... very much. but now... with watercooling, it's not a problem!
    the second LCD is a Crystalfontz 634 usb series, with 4*20 display capabilities.
    --->tetleyex: all details are made with dremel the tools called "high speed cutter" for dremel.....
    erf... the correct sentence is "I am a French modder of computer".... isn't it?
  19. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
    Beautiful conversion :thumb:
  20. Geheimnis
    Geheimnis What's a Dremel?
    3 May 2005
    Zubbione : Good mod ! :)
